"Pushbar" (towball) mounted to Sovereign front bullbar?
  • "Pushbar" (towball) mounted to Sovereign front bullbar?
    I have just purchased a 2006 120 series Prado that came fitted with a factory fitted Sovereign front bulbar.
    In order to get my 16ft caravan into its preferred parking, space inside the front fence, its a very tricky operation to come in the driveway and then jackknife the van at the perfect time to line it up with the fence and then push it in.
    What I have seen done in the past for shifting boats/vans in tight situations is to mount a towball on the front of the vehicle. This gives great control and a much better turning circle can be a achieved.
    Off course, Toyota recommend against mounting a winch or anything solid to the bull bar.
    I would be very interested if anyone has tried this type of thing and how it went. I don't want to set of the front air bags or do any other (expensive?) damage.
    The winch mounts to a separate steel support plate, I don't believe the alloy bar would be strong enough to mount a tow ball to.
      Learn how to reverse?
      *ducks for cover*
        Hi GR1
        Could you get the van to a point with the vehicle then use a ratchet type jockey wheel to move vans into its position?
        Some info and options here http://www.lets-getaway.com/jockey-wheel.htm
        Troy
          Thanks for the reply's guys.
          I have got a ratchet jockey wheel and will give that a try, but have to lay some new pavers to make sure it can get a grip.
          If I do end up with the front pushbar, will have to attach it to the chassis as per a winch mount.
            Hi GR1
            Troy
            I have a ratchet type jockey wheel to manouvre my van into place and it's not bad. Its a bit jerky initially and you need to be sure the jockey wheel has plenty of grip cause if it slips... it's curtain's Irene!
            Micheal.
              Might need to knock one of these up.
                The seat doesnt look very comfortable though
                Micheal.
                  I use an Optitec van mover as where I keep the van couldn't reverse into place even if I jack knifed as have a wall less than 2 metre in front of, carport 1.5 metre behind and wall 1 metre beside van.
                  It has a remote control so can walk around the van while moving so I don't hit wall or carport, needs solid surface to work digs holes in lawn.
                  I get it to a point where it takes 20 mins to disconnect, move, unload and secure same to hitch up.
                  Best thing I ever bought, only use at home too heavy to cart, also did a van reversing course.
                    Hi Sparky, Looks like that unit would move a mountain! What motor did you use? Looks like a 12V. Would it be possible to use a trailing lead with an AC 230V motor? or would it not have the required torque and or need too large a gear reduction. I am a retired mech eng so could knock something up. More details would be appreciated, off line is fine.
                    Thanks, Graham
                      I'm in process of making it m
                      Now. Got idea from one on ebay.
                      Uses a small at w inch remove rope and fit sprocket it then drives a larger sprocket on the axle.
                      Do a search on " myswag caravan mover "for images and it will show heaps of ideas.
                      There is one they make in South Africa that uses a 240 volt motor with a through shaft gearbox that looks easier to make.
                      I've got at home a 200 v dc motor with a 150 to 1 reduction box using a dc motor makes reversing easier . It's got a 25mm through shaft box so just need a shaft and make up some taper lock hubs to fit some quad bike rims.
                      Going to work on it at work as a side project until they make me redundant in August.
                      Got a full machine shop so have to take advantage of . It
                      When I draw up some cad plans ill post them up
                      sparksy
                        Don't knock it till ya ride it Micheal!
