Hi all,
New here, apologies if this has been written else where, but I haven't found it.
Doesn't anyone have the exact weights of the Toyota Soverign bar (with winch cradle) versus the ARB deluxe bull bar??
Also, I have a 12000lb Ironman winch, are you required to remove these bars (ARB or Toyota) from the vehicle to fit the winch??
Ideally if there isn't much weight difference between the ARB and toyota bar, and the ARB allows fitment of a winch without bar removal, i will go the ARB bar. If there is a significant weight difference i will probably go the Toyota bar and investigate whether the winch can be fitted afterwards, or just do it all myself.
Given that I will have a winch, bar and 2nd battery up front, am I going to need to change the springs too??
Andrew
Andrew
