The money is obviously burning a hole in your wallet mate - go the Strongarm in January then us Sandgropers can steal it - oops, I mean admire it, while you're here
Kaymar Rear End Finish
Sandgroupers?Originally posted by Trekrider View PostThe money is obviously burning a hole in your wallet mate - go the Strongarm in January then us Sandgroupers can steal it - oops, I mean admire it, while you're here
Is that where you all Grope as a Group?Last edited by MidLifeCrisis; 09-09-2011, 01:07 PM.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
In Tassy you get to cheat on yourself by using the hand on the side on the other head. At least the other head goes blind before the first you do, as oppoosed to the second you...... ?? describing this is even confusing me.....
Being an old sandgroper and now crow eater, I will just talk amongst myself with the voices in my head. Upside is I get the final say, in one way, shape or other.
BTW, I am yet to see a draft trip plan for early Jan 2012. Expecting a few day trips when I'm there so you gropers/groupers better start getting your shite together please.
Drive over from 30 dec arrive 1 Jan
Depart 12 Jan 2012[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Oh you mean this one ???Originally posted by MidLifeCrisis View Postand now I find out that amts is designing the ultimate rear bar for a 120, but expects this will take at least 2 years.
My gut feel is amts will produce a great result, BUT his 2 years will be 4 years ;p ....... what to do......
Where are the duel wheel carriers?
Where is the cut away diagrams and conceptual fit ups?
what are the tow ratings?
whar are the clearance measurements (compaerd to standard)
I see standards slipping........[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
They should design the bar to go right around to the wheel arch.. this way you have more protection if dropping off ledges when 4x4ing, and you can also run a rubber mudflap as I keep ripping off the standard plastic ones! Looks like I will have to custom make it.... I'm thinking tube might look ok?[b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
I've looked into it and actually called Kaymar about it a few years back... apparently it was cheaper to stop at the join in the rear bumper. I asked if they could modify and make one for me to go to the wheel arch, they said it would cost me too much in R&D.... 6 months later the released the 150 series all the way to the wheel arch!!! bastards![b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
You will also notice for every other model Land Cruiser they all go the wheel arch, but no not the prado 120! Looks like I will have to show them how to do it![b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
Darren from Total Traction tyres has actually made a 2x tube version that wraps around the existing body. The tube is the size of the ARB stuff. His mate totalled the 120 it was built for so he cut it up dammit! Might discuss with him....Originally posted by double_d69 View PostThey should design the bar to go right around to the wheel arch.. this way you have more protection if dropping off ledges when 4x4ing, and you can also run a rubber mudflap as I keep ripping off the standard plastic ones! Looks like I will have to custom make it.... I'm thinking tube might look ok?[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
For Sale AMTS designed rear bumper wheel carrier
I'm in for one when is delivery??????Originally posted by amts View PostOh you mean this one ???
ondaboat
