Plastic guard in wheel well
  • Plastic guard in wheel well
    Hi,
    Does anyone know what type of plastic or rubber the flexible guard flap in the front wheel wells is made out of? I need to make up a new set before my next trip.
    I'm referring to the flap that separates the engine bay from the wheel well that's held in place by push in clips.
    Thanks.
    2008 GXL D4D + Option Pack 1, Safari snorkel, factory alloy bar, dual battery system, Lovells TFR-118/TRR119 Springs, Bilstein Shocks, Prodigy P3 brake controller, factory tow bar, Orac coupling.
    You can use some insertion rubber about 1-2mm thick.
    My Rig Build up
    sigpic
      Thanks. Just ordered 1m of 1.5mm sheet on ebay.
        Clark Rubber has it. Stewy recently made up a couple of replacements recently using the originals as a template on his FGay which are identical to the 120 & 150 Prado
          The original guard flaps deteriorate over time and they are expensive if you get them directly from toyota. Worth considering making your own. The clips are a pain to get out if you want to re-use them, repacements from Toyota again are a bit pricy so shop around or re-use the existing ones if you are prepared to spend the time getting them out in one piece.
          I made stensils of original guards, so if your originals are too far gone to copy I can have a look for them. Let me know if you need a copy .
            just out of interest, anyone know the part number? also looks like a plastic clip to hold it in place part number for that too.
            wouldnt mind seeing the price on amayama as one of mine is that bad a template cant be made.
              NG-5373535150
              NG-5373635150
              NG-5388635020 (X 2)
              CLIPS NG-9046710186
              Purchased All Four x 4 spares (via Ebay)
