I was at OL in Adelaide the other day talking to the rep about compressors and the good and bad points for in cabin mounting. When the conversation turned to lockers he asked if I had heard of a E locker. Apparently the diff lock is activated via 12v instead of the typical air compressor.
I then asked if it's better to install the front locker first or the rear. This is where it got intersting. I was told that in a Prado, you'd replace the rear because the Toyota LSD is a weak link. If it was a Nissan, you'd install the locker in the front because the LSD is tougher.
My 2 questions are, how good are these e lockers and is there any truth in the Toyota LSD being weak??????
Over to you guys........
