I don't think the lock up will be the issue either, I would be more concerned with
the clutch packs and their not being designed to take the full engine load when
changing gears, same for spider gears etc, if you have a motor spinning at
3000 RPM and gear changes up and you have to suddenly absorb 1000 RPM
with considerable inertia behind it may not be good for the clutches or gears.
I believe if the manufacture unlocks the torque convertor before changing gears
he mostly likely does it for a good reason and without knowing what it is I would
try and keep the same functionality in any after market mods.
Would you rev your motoring to 1500RPM then throw it into drive, no you wouldn't
because as you know it would not be good for the gear box, but with torque convertor
locked and changing gears is more or less the same thing.
If you ride a motor bike then you would most like up shift without using the clutch as with straight cut gears and quick changes where engine speeds quickly fall to match transmission speeds up shifting without using the clutch is normal. You wouldn't do the same down shifting though as your then have to speed the motor up and all you do is lock up the rear wheel and put a hell of a load on everything.
If you only intend to keep the car for a short time then it may not be of concern.
