See more
See less
1kz-te Transmission pan drop and filter change
  • 1kz-te Transmission pan drop and filter change
    Hi,
    Looking for a guide on how to drop and replace the transmission filter in the 1kz-te engine.
    I have no problem just flushing the fluid but wouldn't mind doing the complete service.
    Mines in a 90 but I think they're both still the 4-speed so should be same.
    Helps if you have another vehicle as there's two different filters and you get differing opinions which one suits your trany. Easiest is to take in the old filter.
    I dropped the oil first, there's a convenient drain plug.
    Then undo all the pan bolts, drop the pan and the filter is looking at you.
    A couple more bolts and the filter drops off.
    The pan will have some loose magnets stuck to it so take care when cleaning it.
    Your replacement filter kit will come with a new pan gasket.
    Then just put it all back together.
    Re-fill via the dip stick, takes around 5 litres but check on the stick with her running in park. Go through all the gears and check again.
    The convertor will still have old oil and the only way to fully replace all that oil too is with a complete flush, which is usually a professional job.
      Originally posted by Ryanie90 View Post
      Hi,
      Some useful inks here I hope Ryanie
      https://www.pradopoint.com.au/forum/...n-fluid-change
      https://www.pradopoint.com.au/forum/...ty=&viewfull=1
      CheersTroy
        Thanks guys,
        Managed to do it quite easily.
        Dropped the pan and replaced the filter - removed the dipstick bolts which wasn't required as it has two parts and just slides out. Was a pain in the ass getting one of the bolts back in..
        Removed the old hoses into the radiator and replaced with new ones
        Flicked the engine on before connecting to radiator to identify the return hose
        Had someone in the car and another filling through the dipstick while I watched the auto fluid run into a container
        Once it changed shade flicked it off and moved through the gears.
        Filled up and took it for a run, required another fill the next day as the new fluid worked through the gears
        Job went fairly easy.
          NOTE: With 1KZ TE engine using the hose connection to the radiator to drain Fluide, it is the BOTTOM hose that is the return hose, not the top hose as in AMTS discussion (1KD Motor). I changed my oil today and used the top radiator hose connection only to find oil sprayed all over the engine bay and onto the driveway!!! Bugger!
          2004 120 - 1KZ Diesel, Custom Ironman 45710FE 436-569mm with Dobinon C59-352, Custom Ironman 45682FE 383-618mm with Dobinson C59-627, 30mm extended Roadsafe links,, Recaro Drivers Seat, ARB Delux Bull, LED Driving Lights, 1200lb winch, BF02's, LED's all round, Cage Rack, Duel Batts., Airtek Snorkel, Awning, Black Widow drawers and barrier, 40L Engle Fridge- all fun!
            I too found out the messy way that previous owners may have mixed up the hoses.
            Easy way, working from the trany, the metal pipe which has the over temp sensor is oil out.
