What diff ratio do I have?
  • What diff ratio do I have?
    Hi guys was hopeful that someone can help me out quickly on this one. I have a 2005 prado gxl diesel auto and have blown the rear diff. And need to get another so that I can slip in the Elocker that I want. Problem is I don’t know what other model vehicles I can get the diff centre from or what ratio I need. So far a have been told it is either a 3.9 or a 4.1 but need more clarification than that.
    To help out my vin number is: jteby29j400030672
    thanks
    Marko
    It'll be 4.1:1. All the 1KZ 120s have that ratio. You'll have to find another KZJ120 for a donor as all the other models are different ratio. Some use the same centre ie 3.91:1 and up use the same centre as the 4.1s I believe, but obviously the crownwheel and pinion would be different. Problem with finding a 4.1 from a KZJ120 is the Hilux guys have pushed the price up at the wreckers as they want them - to bring the gearing down for fitting larger tyres.
    adrian5800
      Does that mean I can put Hilux centres in my kzj120 6speed for taller gears? My first gear doesn’t even get across an intersection and I’m flat out going 140kph on the highway.
