Well, directly to the ECU from the accelerator pedal yes - the throttle body itself is fine as that runs direct to the ECU from the front of the engine. Those wires weren't touched. IC3 is behind passenger side dash:
http://s1344.photobucket.com/user/pi...e6ce9.jpg.html
So what it looks like... is that the brown/white wire runs from the accelerator pedal out that rubber seal, across under the windscreen in the engine bay to the passenger side seal and back in to the back of the IC3 plug. I'll test that this solves the issue by direct-wiring from the accelerator pedal and splicing onto the IC3 wire and if all is good, will run it properly out through the engine bay.
What I haven't been able to find is what gauge this wire is. Any ideas?
