Alternator Output
    Originally posted by mackayvx View Post
    Hey azz.
    No ive got the kzj with the 1kzte. But wow 14V charge?
    Thats insane.
    I think my problem is with the roof mounted DVD player that is wired into the same circuit as the interior lights.
    Having constant power to it enables the kid to leave it on....
    I think ill remove it... Seriously who watches DVDs these days anyway?
    The diode's work a treat, gets around 13.6-14V, and are worthwhile if you have a second.
    With the DVD player, just buy a DC-DC relay on ebay and wire up the ignition wire to the relay so it can only have power when the car is on...
      A dc-dc relay hey? Ill have to look into that one.
      Thanks philski!
      HERS - KZJ120, BILSTIEN / KINGS, AMTS GEAR, RHINO GEAR, OUTBACK DRAWERS ETC ETC ETC
        Thanks philski!
        no worries, you can get them on ebay - like this
        http://www.ebay.com.au/itm/12V-DC-Bo...ht_2970wt_1397
        you just need to run a separate wire from your ignition (find it with a voltmeter) to the relay switch then power it though the relay. Plenty of wiring info online if you are not sure.
          Originally posted by gxl_d4d View Post
          The alternator is a 120A output according to the user manual. The output can be increased by 0.6V by installing a diode in series with the alternator sense pin. If that's not enough, 2 diodes will give a 1.2V increase.
          How do you use 2 diodes? or is there a diode that increases 1.2 volts verses 0.6 volts ?
          Robert
          [B]Robert
            Can someone put up a link to the diodes on eBay? I don't really know what I'm looking at.
            Thanks in advance,
            Josh
              Thanks in advance,
              Josh
              http://www.ebay.com.au/itm/Prado-Hil...item337f1fb187
                Thanks Andrew!
                Appreciate it.
                Josh
                  Soooo, does anyone have some hard facts on the Alternator output of a D4D 120 series Prado?
                  I have heard, 80 Amps, 90 Amps, 100 Amps amd 120 Amps being mentioend. So what is it?
                  Anyone got the spec from Toyota on this. Help me Obi Wan Gu"Roo"...
                  gumboot
                  [B]Robert
                    I think it depends on where you buy your Prado. From toyodiy.com, it shows that there are (were) three OEM types of alternators:
                    27060‑30050 12V 80A
                    27060‑30060 12V 100A, COLD SPEC
                    27060‑30070 12V 130A, DENMARK SPEC&COLD SPEC
                    The way I read it, the 80A is fine for most countries. The 100A is for use in cold climates, and for some reason the Danes feel that their cold is colder than the rest of the Northern Hemisphere, so they get 130A.
                    Someone else would have to say whether or not you could install a 130A alternator in a car that is in a warm climate without damaging anything, or whether even doing so would add anything of use.
                    ______________________________________________________________________________________________________________
                    2003 LC120 (European Prado) 1KD-FTV 3.0 D4D. All stock including standard transmission. Apparently not one of the VIN numbers that has an injector seating problem but keeping an eye on it anyway....
                      The Prado Manuals I have (on CD) for models 2004 - 2008, show for all Aust models, Alternator output is 960 watts (80 amps)
                        the 130Amp sounds nicer though as an upgrade...
                          Does anyone happen to know, if my original alternator is the 80amp version, can I put the 100amp or even the 130amp in there without hurting anything? That's to say, can I just drop it in there, or are there other items that I will then have to replace?
                          • #28
                            Swapping out an 80 with a 100 shouldn't be a problem, swapping out an 80 with a 130
                            might. You would need to look to look at the output wire for the alternator and determine
                            if it can handle the extra current. You would also need to replace the fusible link for
                            the alternator and also determine if the contacts/connectors for the fusible link can
                            Leigh
                            • #29
                              Excellent, thanks - I think I'll stick with the 80amp... don't want to go spending extra money for unknown benefits and chance of damaging other things. Not the time of year in Prague to be trying to peer under the hood (minus 12 and snowing).
                              Clive
                              • #30
                                Keep in mind, that simply increasing the size of your alternator will not change how much the car actually draws from the alternator.
