Hi Guys
"Providing that the EGR "is" running correctly it will reduce Nox levels and the engine will perform more stable power and engine temps.... I did mention this quite some threads back! (People should read this whole thread from beginning to end then the full picture will come light!).
http://www.pradopoint.com/showthread...l=1#post306700
This link below is to an open link on the web so i see there to be no breach of copy writes as only viewing it from its sorce!
Exhaust Gas Recirculation System EMISSION SUB SYSTEMS ...
www.autoshop101.com/forms/h61.pdf
File Format: PDF/Adobe Acrobat
performance and fuel economy can actually be enhanced when the EGR system is functioning as designed. EMISSION SUB SYSTEMS - Exhaust Gas ...
Quote diver70: Would there be any benefit in fitting an oil catch can inline here? Aren't they designed to trap most of the airborne oil, so the remaining bit of air passing through the EGR system can be burnt without fouling everything else with oil? Just seems like a simple solution that would not create any error codes or performance losses.
Answer skywalkerrun: Yeahh! "Finally"... some one read the thread and got it! ... Lol
I personally would leave the EGR alone, Fit a good oil catch can and "DO NOT" restrict or block the EGR on the 1KD-D4D's as it "Does control peak combustion temps and the D4D needs that EGR passage to dump its access turbo boost.
I will not go into detail explaining the process again as i have already written it in the past threads in great detail. (Just read the whole thread as it is only three pages!).
PS When i am logged in there is only 3 x pages but it actually spans out to 10 x pages when logged out!....
Happy reading Lol
Happy reading Lol
