Have a 2008 grande diesel. I have a steinbauer chip and beaudesert exhaust for 4 months. Only done 65 k and now my engine mounts need replacing. Does anyone know how long you should expect the mounts to last and if this mod may require stronger engine mounts, if you can get them
Engine mounts
My 2008 model also has this issue, has been looked at by dealer and a claim approved
for their replacement under extended warranty.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
I haven't looked at mine however I used to break the LHS front mount in my GQ if I hit the loud pedal too much. They were the 2 bolt version and in the end I used piece of seatbelt webbing between the two bolts. Enough slack to the let mount do its thing but not enough to let it break. Solved my problem.[url=http://www.myswag.org/index.php?topic=12264]My Prado[/url]
I suspect my 08 is in need of replacements. Looking at the location its a wonder they are even able to get to them to swap them out. When Im stopped at the lights on a cold morning I get a shake, but popping it back to Neutral its OK. It only seems to happen on cold mornings, when temps are around 10 degrees and colder. Whats the cost to swap out the mounts?[b]Silver 2008 D4D Auto GXL[/b]
A Toyota Service Manager actually told me to look out for engine mount problems, so reckon they are aware. Just add engine mounts to the list, like cracked dashboards and rattly steering columns. Prado's are good but they sure aint perfect
Cheers.....wayneWhite 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
Rodh.
Yep... I bought a 2007 gxl D4D new. First engine mount went at under 5,000km, next just before I went outback at 50,000Km. Now at 70.000km and expecting next to go. Love the car....hate the engine mounts!!!!2018 GXL Prado 150. ARB bull bar, Uniden UHF, OME suspension 2 1/2 inch lift, Pirahna Dual Battery system, ARB Compressor, BFG AT's, Engel fridge,Outback Sturt Offroad Camper,
Is this an issue with a bad batch? I haven't had any problem with mine (just over 100,000kms) and none of the Prados that come in at work (workshop) have ever had the problem either. We have eleven D4D Prados in the fleet at my other work, and none of them have had any engine mount problems that I am aware of either.2008 Diesel Prado with extra stuff added. I drive it on the road and other places too.
Had mine replaced when the car was new, under 10000 km. the dealer service manager picked it by what felt like a miss fire, saying the mounts where to blame. The mounts are actually have a chamber that is hooked up to the vacuum lines. This is to isolate vibration and noise. Now done almost 120000 and no issues. Only issue with the car is the tailshaft clunk.08 VX D4D, Lift, Safari Snorkle, Trailblazer Fridge, Custom Storeage System, BFG, ARB Safari Bar, Wife, Kids, Codan NGT HF Radio, Debt.
Just had mine replaced by Nunawading Toyota, cars like new again, no
harsh vibration when shifting into reverse and drive. Engines idling smoothly
and can't feel the aircon compressing switching in and out.
cheers
LeighWHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by sleeky5 View PostHas anyone actually changed the engine mounts themselves and if so how difficult is it to do. Bridge Toyota in palmerston quoted 2 hours per side which seems well over the top. They said it was very fiddly.
Also asked whether Toyo would cover the costs of the mounts seeing as though I reported it twice in the warranty period and that they would have to put a claim into Toyo, but didnt sound too promising there.
As a FYI, my issue only seems to pop up during winter and only ever so often so I'm not overly bothered at this stage (especially I know my injectors are still good )[b]Silver 2008 D4D Auto GXL[/b]
