Remote Central Locking Problem
  • Remote Central Locking Problem
    Hi All
    I'm not sure if this is the right part of the forum for tjhis post. I live in a Glen Innes in NSW which is a small country town with a wide main street. I've noticed that if park my 2007 120GXL in a certain section of the main street my remote central locking doesn't work. The first time it happened I changed the batery in the key and when I got home I locked the car without a problem. I thought this had solved the problem until I parked in the same spot again a few weeksn later and again the remote didn't work. I moved the car down the street and the remote worked again.
    So my question is can something like a wireless network or security system interfere with the remote central locking?
    many thanks
    Bigpat
    A Prado Newbie
    Sure can
    LeighW
      I have had similar problems two or three times when I have parked at MacDonalds. Different mainland towns each time. I have suspected some radio interference problem.
      Ron.
      2007 D4D Manual GX, ARB bar, Coopers, Dual Batteries, Codan HF Radio with rear HF Bracket, 2M VHF, 70cms UHF, UHF CB, APRS, Tom Tom GPS, Rally Computer, Waeco Fridge, In-built Water Tank.
        I had a similar problem with my old 90 Series Prado (with aftermarket alarm/immobiliser) when parked near a large TV station or radio antenna. The problem would only occur sometimes and it depended on where the car was parked. On a number of occasions it took a few tries to get the car to unlock. On one occasion, I couldn't unlock the car at all. I had to use the key to open up the car. The car would not start. The starter motor wouldn't even turn over and I put it do to interference jamming the immobiliser. It took me a good 5-10 minutes of trying to disable/switch off the immobiliser manually before the car fired up. After that incident, I never had a problem again.
          There is a place in SA on the escarpment overlooking the City where due to some radio towers wireless items do not work at all and there are a few signs telling the public to lock up manually. Radios also do not work.
            MLC, have you been up stealling the signal again... ? I promise i wont tell anyone...
              Thanks All
              Seems like I was not going mad afterall.
