rattle under the car
  • rattle under the car
    Hey guys i have a bloody annoying as rattle underneath my car somewhere and i cannot locate it. happens when i hit small bumps and imperfections in the road and there is a small clunk when i apply brake pressure.. the rattle almost sounds like there is a washer on a bolt thats not tight enough but i have been over anything and can't find it.. I'm sure someone here will be able to advise me of what it could be...
    cheers guys
    Do what i do... Turn up the radio, problem solved :P
    I have a lot of those noises myself but not when braking, If it does this every time you brake i would be looking closely at your brakes/bushes/suspension component somewhere.
    I get all sorts of rattles going down a bumpy road, mine comes from front right side guard and drivers door where some clips need replacing, also having bash plates might contribute to extra noise.
    GL with getting it sorted, let us know what it is when you do.
    Zutta
      Me too. I've found stones in my skid plates which I've removed and checked most suspension bits and bobs and still can't track it down. Had it about 6 months but got worse recently. Been suggested elsewhere that it's a missing backing plate/clip on the brake pads. Having mine checked in a week or two.
        Tucky88, you have described almost the same rattle I have. One time I found a captive nut that come off or factory surplus most likely rolling around the chassis. Run over a bump and I get a rattle left side just as if it's a loose bolt or nut. Could be me starting to rattle loose lol
        Love to know what it is before I do a long trip on the corrugation.
        Hazza
          If you've eliminated everything mechanical it could be something such as a rock bumping around inside your chassis rail? When you hit the brakes it might be rolling forward to hit the end? Just a guess.
          Sent from my GT-P5110 using Tapatalk
          2005 GXL KZJ120 3.0TD. Goodies: 2" TJM XGS Gold Suspension Lift, Safari Snorkel, TJM Underbody Protection, Sovereign Bullbar, AMTS radiator guard, spare wheel spacer & soverign bar LED lights, Runva 11XP Winch, Front Recovery Points, BRC Quad Breathers, Rhino-Rack Pioneer Platform, IPF spotties converted to HID, Drifta Drawers D2D-WT, Autosafe Cargo Barrier, Uniden UHF, 265/70/17 BFG AT's.
            I would me more concern finding the baby you ran over rather than looking for its rattle
              i think the sway bar bushed are shot... will be getting replaced soon.
                well i pulled the sway bars off on the weekend and went for a drive and it definitely not the bushes.. i believe it make be in the brakes somewhere but when i took all the wheels off to see if the callipers or anything was loose it was all tight as with no play. The noise is def not a rock or anything, its more metallic.. doesn't effect performance or anything but is very aggravating so my fault finding will continue.
                  I think I have the same sound, well I did until I had the motor out, let me see if its still there.
                    i have read a few things about some clips not being replaced properly when the brakes get done.. when i bought the car the previous owner had the brakes replaced so i was wondering if that should be the cause or possibly something to do with the hand brake.. when i am parking the car and go from forward into reverse and visa versa it makes the clunking noise as i am applying the brake... has me rather confused..
                      There are anti rattle clips on the back of the pads. They can be left off or work loose.
                      New front pads & rotors and steering rack fixed my rattle. 99% sure the pads and rotors fixed it. The rack issue was discovered when looking for the rattle.
                        When i had the 120 the baffles in the muffler had come loose and were rattling now and then. Just a thought. Good luck
                        [INDENT][CENTER][SIZE=4][B][URL="http://pradopointgtg.org"][COLOR=#000080]PradoPoint GTG 2014 - [I]Iconic High Country - Victoria[/I][/COLOR][/URL][/B][/SIZE][/CENTER]
                        [CENTER][SIZE=3]Big Thanks to Our Sponsors - [/SIZE][SIZE=4][COLOR=#ff0000]ARB 4x4[/COLOR], [COLOR=#800080]Dobinsons Springs and Suspension[/COLOR], BCF, [COLOR=#008080]Terrain Tamer[/COLOR], [COLOR=#696969]ORU[/COLOR], [/SIZE][SIZE=4][COLOR=#ff8c00]Maxtrax[/COLOR], [COLOR=#0000ff]Traxrax[/COLOR], [COLOR=#800080]Brains[/COLOR], [COLOR=#ff0000]Redarc[/COLOR], [COLOR=#008000]Opposite Lock[COLOR=#222222], [/COLOR][COLOR=#0000ff]Kaymar, [/COLOR][/COLOR][COLOR=#ffa500]Hema Maps, [/COLOR][COLOR=#ee82ee]pure-sense, [/COLOR][COLOR=#696969]Bushskinz, [/COLOR][COLOR=#ff0000]Piranha Offroad [/COLOR][COLOR=#800080]High Country 4x4 [/COLOR][COLOR=#222222]& [/COLOR][COLOR=#808080]Century Batteries.[/COLOR][/SIZE][/CENTER]
                        [/INDENT]
                          I had a rattle once, it was those stupid captive nuts ARB use for the under bar plates. They had become un-captive due to being over torqued when installed and thus the plate was hitting the bar. Hard to find without getting underneath and giving everything a hard hit. Replaced them with flange bolt/nuts and haven't had a problem since.
                            The sound or clunk you get when changing direction forward reverse reverse forward is normal. The pads are designed this way so the release away from the rotors to reduce friction while driving. My wife's CRV now over 10 years old does the same. If you take the wheel off and look closely you can see the pads are on a slight angle and they mostly do not touch the rotors.
                            Hazza
                            Hazza
                              My rattle turned out to be a spanner somebody had dropped down between the fuel tank and bash plate and never retrieved.
                              Nicely engraved with initials NB.
                              Ex 1988 Mitsubishi Pajero V6
                              Ex 1986 Suzuki Sierra
