  • Got a 2" lift on Thursday and finished making my sliders and fitted them today (big job)
    Photo attached.Click image for larger version
Name:	Sliders done 22nd Mch 15.jpg
    Brian
    • Brisey,
      Sliders look great. What sort of suspension upgrade and lift did you get? Just finished reading the horror stories about OME and now have concerns as my 120 is booked in get a suspension upgrade this week. It's not too late to change my mind though so would appreciate any reviews you have after the first few days.
      • Originally posted by Retreads View Post
        Brisey,
        Only went for a 2" lift rated to 150kg I think as I still wanted a comfy ride for daily use, I love it so far very little difference in fact probably better than before as the stock shockers were on their way out. Easter will be their first test, we are going to the Vic high country out of Mansfield.
        Brian
        • So I had a few free days and wanted to add a fridge slide on the rear. On previous Utes I never had a housing or compartment so every time you pulled out the fridge, everything would fall in behind it. So decided to make this. Could have done the whole thing out of 15mm ply and save a bit of money but that would have made it heavy. Instead made the base of 15mm and the structure out of aluminum then the top and sides out of 7mm ply. It's all very light until you add the fridge slide which is pretty heavy by itself. Worked out pretty cheap compared to something premade Plus getting the satisfaction of knowing I did it all myself
          It takes up a heap of room in the back but thats ok as we tow a camper trailer and most things except for food goes in there
          2008 Prado 120 GXL V6 auto. Stock...but slowly building it up
          • Drained and refilled front diff, transfer case and rear diff in preparation for the Drive4Life charity drive in the High Country next month.
            cheers
            Jim
            • Had a 3 inch Redback exhaust fitted, What a massive difference both in sound and performance.
              Quality bit of gear.
              Cheers Craig
              • Replaced the headlight globes as both had simultaneously blown low beam. They were Narva plus 40 blue. Gave the beasty a wash and removed the M/Ts and replaced them with my BFG A/Ts.
                • With sound is it really noticeable as I don't want something noisy and causes a drone on the highway at speed. Any feedback you have?
                  • No drone at all, sounds great nice note and nice turbo spool up noise. The beauty of the redback system if you want to quieten it down you can just bolt in a muffler. No need though.
                    • Just filled up today and been recording fuel economy since last fill up.
                      Got this much out of it and decided to fill up now because fuel prices will go back up tomorrow.
                      My Litres per 100kms
                      Also did this a while ago
                      • Finally fitted up a second fuel filter today. Easy job. Running out of room fast in there.
                        Blake
                          Yes agree - no room for V8 now.
                          • Just did a oil change for first time at home today and installed the long awaited fumoto oil valve. Now to see how things go with it. So far it doesn't look like it sticks out from the bash plate to that's good at least.
                            • Used the winch to remove a stump from the back yard. Car was out the front with plenty of rope through the side gate. Neighbours were curious.
                              • ^^Neighbours have probably watched 'YouTube Fails' and were having visions of your stump ending up in their lounge room
                                2009 GXL D4D White Auto - ARB Duluxe Bar - Lightforce 240 Blitz spots - Icom IC440 CB - Bilstein shocks, Lovells 1.5" lift H/Duty coils - Polyairs - Tracklander Alloy roof cage and ladder - Maxtrax - rear work lights - PP Rear-door-table - Underfloor water tank - 275/65/17 BFG AT's - Ranox dual battery system - Rear door spacer - Safari snorkel - Steel sliders - ARB front and rear air lockers - ARB CKMTA12 onboard air compressor...
