Originally posted by Mattfunk 120
View Post
Good to see you have a sense of humour too.Originally posted by Wtrxprs007 View Posthaha all good. i'm just really used to using centimetres for a lot of my measurements2008 120 GX D4D with a few extras
Rig build here
I did my first service today (with my brother in law's help)
Penrite 10w-40 fully synthetic oil, Ryco oil filter, Ryco fuel filter, Ryco cabin filter.
Cleaned the maf and k&n filter whilst at it.2007 GXL V6 - ARB Bullbar with LED lights, snorkel, extractors, 2 1/4" dual exhaust, K&N filter, dimpled/slotted rotors, headrest dvd players, Ebay Satnav/reverse camera, GME 3100TX, Tigerz11 Side awning on custom brackets with Maxtrax mounts, 300W Invertor, ARB Underbody protection, Lightbar and STZ 265/70 tyres.
May I suggest getting rid of the K&N and putting a paper filter back in. K&N or similar filters don't play well with MAF sensors. The oil out of the filter creates a film on the sensor, causing it to read incorrectly, particularly if the filter is over oiled. If you choose to keep it make sure it's not over oiled and make sure you clean the MAF regularly, I would say at least every 5,000Km. If the oil is left on the sensor it can build up a tarnish which is very hard if not impossible to clean off without damaging the sensor. Good work on learning to service it yourself though.[LEFT]Silver 150 Facelift
Good advice. I'm going to do the same.Originally posted by AussieAndy View PostMay I suggest getting rid of the K&N and putting a paper filter back in. K&N or similar filters don't play well with MAF sensors. The oil out of the filter creates a film on the sensor, causing it to read incorrectly, particularly if the filter is over oiled. If you choose to keep it make sure it's not over oiled and make sure you clean the MAF regularly, I would say at least every 5,000Km. If the oil is left on the sensor it can build up a tarnish which is very hard if not impossible to clean off without damaging the sensor. Good work on learning to service it yourself though.
On another note. Put in the repco knockoff version of the Bosch wipers today. Absolutely brilliant (although expensive for all 3). So much better than OEM! Now just need to find some hilux sprayers!
Not sure who you asking that question? But regardless, I have had a bonnet scoop fitted to mine for over 5 years now and I would say that any gains in performance or cooling or fuel economy, if they exist, are so minuscule that its not worth worrying about.Originally posted by Armydorf View PostDoes you bonnet scoop make a large difference to the intercooler performance ?
The only reason for a bonnet scoop is looks, IMO.
Plenty of people have fitted aftermarket uppers to their Prados. I have SPC arms in mine, they are sold here by fulcrum suspension. Keeps the alignment in spec and drives exactly the same as the originals did, win as far as I am concerned.Originally posted by Armydorf View PostAnyone fit new Upper Control Arms (Superior Engineering do a good one) to their 120? Was it worth it?
Armydorf[LEFT]Silver 150 Facelift
Installed LED internal lights bought from PP suggestions from here: http://www.ebay.com.au/itm/261940065...%3AMEBIDX%3AIT
However, two door lights and one back door light would not work. No problem with circuit as they were working at the time.
Have to return them. Despite that am very pleased with the results - specially the map lights.Terry
Canberra
For my 2003 Grande I got a Locksmith to fit me the new type flip key with the original unlock/lock transponder chip inside. No more key scratching my cell phone!!
A few days prior I got the ole 1KZ dyno tuned (has a Steinbauer chip plus 2.75" Beaudesert Exhaust). From the wheels it got tuned from @72KW to a now 81KW. They also adjusted the boost to lean off fuelling as it was running really rich..so it's now got a manual boost controller.
Boost gone from 10 psi to 12 psi, seems to run a lot better now and a few days earlier the original steel cable winch was removed from the alloy bar which must have weighed around 30 kgs!!! I'll put this in the 'For Sale' when I work out what bits go where...it's truly a monster though, the cars suspension bounces more as a consequence though as there is more travel in the shocks??[SIZE=1]03 TD 120 Grande, L&R weathershields, f&r deflectors, Sov bar Amts rad b.pl, TJM front B.P, Uniden UH7760NB Kaymar LED worklight, ARB 47l, lifestyle rack & Milford C. Barrier, 9500llb Superwinch, IPF 900SR spots, T. Dog 40mm adj shocks/struts, coils, airbagman OA6011 airbags, 2.75" Beaudesert exhaust, 300w inverter, 1L Catch can,outback rec points, R.R awning, dual batteries redarc SBI12 Cooper LT A/T3's 265/65, Safari snorkel, Hilux jets, Brains TG150, Leigh's booster diode [/SIZE]
