any luck out there for the l/100km readings?
Installing OBD2 bluetooth scanner on M-OBD Prados
This is a sticky topic.
Originally posted by joanbrugal View Postany luck out there for the l/100km readings?
- 1 like
Originally posted by amts View PostFor those with the 1KZ, can you get the following readings:
1. Fuel economy (average, instantaneous)
2. Transmission temperature
i get a auto temp reading but seems to give same reading as coolant temp (using method 3) method 1 and 2 give no reading
2004 1kz 4 speed
Hi Guys,
I got my OBD2 connector this morning - got this one:
I have a late model 2007 1kd and the Torque pro app and it worked without any set up. It doesn't seem to have all the sensors etc covered, but perhaps playing with the settings as others have will reveal more data.
I am really interested to see if this thing can get the injector values. If i get it right, i'll let you know how.
Andrew
Andrew
Mine's a manual so obviously trans temp isn't available.Silver '04 KZJ120~Manual~GXL~Dobinson/Kings lift~Custom valved Ironmans~Detroit Locker~Endless Air~X9 Superwinch~Madman EMS1~TJM Dual Battery~Rhino Roof Tray~120W solar panel~Foxwing awning~Bushskinz UVP~Long Ranger water tank~Bushman fridge~Steinbauer P-Box~Beaudesert 2 3/4"~Airtec Snorkel~TJM Sliders~Prico Boost Gauge~BFG-KO2s~TPMS~GME TX3420~Front and Rear Cameras~Ultimate Camper hanging off the back!
I have followed the steps and I have a successful connection to my 1KZ (Jun 04). I cannot get any AT temp data? The only options on my Torque Pro are method 1 and 2, there is no method 3. There has to be an AT temp sensor because I have seen the AT TEMP warning light come on.
Any help please?
