Hi guys
As a new Pradopoint member I thought I'd drop a post about my '06 GXL that is causing me some grief. I have seen this post elsewhere so assume some of you may have the solution. Basically I only get cold air out of the driver's air vents. The passenger vents are produce nothing more than ambient temp air. All vents have good air flow. In an attempt to solve the issue I disconnected the heater hoses completely - no change. Local A/C guy said the gas was OK as the driver's side was cold. I just don't get it. With the fan blowing through the evaporator and no heater connected, why am I not getting cold air on the passenger side??
