AJ120 Rear Bar / Dual Wheel Carrier
  • Originally posted by djnapkin View Post
    Well I will be in the market for one of these, but unfortunately not too soon. Split the rear bar today doing some off-roading (see pic), but with a Cape Trip planned for end of July, funds just will not permit at the moment. I hope you're still making these in 6-9mths time.
    [ATTACH=CONFIG]15821[/ATTACH]
    I think I will be able to help you out when the time arrives
    Enjoy the cape, I know you will as its almost impossible not to.
    • Originally posted by Bourkey View Post
      Added my Mud Flaps today and I'm pretty happy how they turned out. I did the same as Ghost and used Flexistrut/Unistrut 30mm X 30mm slotted angle. We use loads of it at work so it was a no brainer. 8mm cup head bolts, washers and nuts. The 6mm insertion rubber I just grabbed from Clark Rubber. I even gave the cup head bolts a quick spray with some black enamel paint so they aren't so noticeable any more.
      Bourkey, I am the latest recipient of an AJ120 Custom Rear. Do you or Ghost have a Mud flap parts list? I have the rubber already, but need to know bolt sizes, drill hole sizes, bolt count and length of each type of Flexi and Unistrut.
      Thank you in advance.
      • AJ120 Rear Bar / Dual Wheel Carrier
        Hey mlc welcome to the club,
        The parts I used were:-
        16x m8 x 30mm high tensile nuts and bolts brought in a bolt packs from bunnings
        1x 30mmx30mm x 2.5mm x 900mm gal angle
        1x 20mmx 2.5mm x 900 gal flat bar
        I cut both gal angle and flat bar to 300mm to match the width of the rubber I had.
        With the flat bar at the top I had to bend it into a dog leg to clear the body work. Will try and take some close up pics in the daylight to give you an idea, aswel as some bolt hole distances.
        • Hey AJ,
          what are your recommendations around using weight distribution hitches with your bar?
          It looks considerably more solid than a HR towbar with the additional chassy mount so I dont think it would be a problem, but just wanted to hear your view or the view of others who are using this combo?
          • Originally posted by Hass View Post
            Hey AJ,
            What I think and what I can say are probably 2 different things. I haven't had the bar tested with a WDH and therefore cant give any guarantee as to its performance. However the short version of the many pages of engineering stats, facts and figures I got from the testing is that it "passed easily".
            Also having looked at a HR 120 towbar I cant see how they would be any stronger than mine and they are fine with a WDH, but as I said I don't have the engineering report to back that up.
            • Originally posted by Ghost View Post
              Thank you Sir. Hopefully I will get onto this soon.
              • Hi AJ120,
                Any change that this bar could be modified, somehow modify, to accommodate a back winch?
                Borec
                • Originally posted by Borec View Post
                  Hi AJ120,
                  Borec
                  I doubt it could be "modified" for that, it would need to be a complete new design, even then not sure how you would mount a winch to a rear bar without having a massive amount of overhand or some major chassis modifications.
                  There is a decent amount of space between the rear crossmember and the fuel tank, that's where I would look at mounting a winch if I ever went that way.
                    I will start to look into it, I have plenty of time at before 2020 :-).
                    • Hi AJ120 what size is the RHS you've used for the main section of the bar.
                      • 125 x 75 x 4
                        • Hey AJ, have had my eye on your handiwork for some time. Can you post some pics of how you mount all the accessory connectors - trailor socket, anderson for trailer, and anything else - reverse camera, airbag valves????
                          2005 V6 VX Pearl White with more and more extras thanks to PP
                          • Hi Cookie, sorry for the slow reply but I have been out in the desert for a couple of weeks and off the grid
                            I just drilled and tapped into the bottom of the main bar to mount Trailer Plug and Anderson plugs.
                            I will try and grab some photos tomorrow when its lighter.
                            • Well Aj120 it's been 5 years since the conception of your rear bar wheel carrier, How is it holding up? and do you still make them?
                              2006 GXL, D4D, White, Sovereign Bar with Winch, 265/70r17, 2" lift, Recovery Points, Max Trax
                              • Pretty sure he isn't making them anymore. Maybe a PM or email will get an answer, he isnt around too much nowadays
