A 2" lift with standard airbags is quite ok. The standard airbags only dislodge when long rear shocks are fitted, not as a result of a lift. If you limit the rear shock length to about 580mm, you should be fine.
Pinning the standard airbags is ok for shock lengths up to about 595mm, beyond that I believe the standard airbags are too close to length limit unless some sort of spacer is used.
Airbag Man airbags are ok for shock lengths up to 625mm and are long enough not to require pinning or retaining.
