Suspension Measurements 2
This is a sticky topic.
  • #76
    Re: Suspension Measurements 2
    Just checked my ride height measurements again out of curiosity after almost 1 year of use. Recently added poly air bags to the rear but these measurements are with them deflated.
    Original measures: Front 785mm, Rear 815mm
    Todays: Front 775mm, Rear 805mm
    Hopefully they don't shrink anymore. KMK
    2004 3.0L TD GXL manual, Bilstein & Lovell springs 2inch lift, PolyAir Bags in rear, Piranha Dual Battery tray, Baintech Battery Isolator, Toyota Electronic Rust Protection, Sovereign Bull Bar
    • #77
      2008 GXL D4D Manual. Standard suspension.
      Front 755/760
      Rear 770/765 (Rear seats removed, Lifestyle Rack, nearly full tanks)
      • #78
        Just took measurments prior to having Ome and delux winch bar fitting today. Have arb dual battery fitted, full fuel and rear seats removed
        Fr 740mm
        Fl 740mm
        Rr 760mm
        Rl 750mm
        measurments after fitting
        Fr 790mm
        Fl 785mm
        Rr 810mm
        Rl 810mm
        2003 GXL 3.0 TD, 60 lt waeco, ARB dual batery, OME suspension, ARB delux winch bar, Desert sky camper trailer
        [url=http://www.fuelly.com/driver/valleygxl120/prado][img]http://www.fuelly.com/smallsig-metric/55972.png[/img][/url]
        • #79
          Just had my Std height Kings Springs and Bilstein shocks fitted to my 2008 GXL Manual D4D Prado.
          Std as delivered no extras:
          Front 750 mm
          Rear 770 mm
          Std with ARB Deluxe Winch Bar, Dual Batteries, IPF 800XS, TJM Bash Plate, Rear Drawers + Waeco fridge slide, some recovery gear.
          Front 740 mm
          Rear 765 mm
          Kings Springs, Bilstein Shocks - collar set at three (highest), Firestone Airbags (5 psi)
          Front 775 mm
          Rear 810 mm
          Looks great, rides great, is great.
          Sorry I only have "after" photos.
          I have now fitted lifted King Springs, Bilsteins - set at three (highest), Firestone Airbags (8 psi) plus spacer (27/07/2009)
          Front 800 mm
          Rear 830 mm
          Photos soon
          Regards
          Garry
          2008 GXL D4D Manual, ARB Delux Winch Bar, IPF XS800, Dual Batt, 50 mm Kings + Bilsteins, Firestone Airbags, TJM Bashplate, GME TX3420, Trak Tech drawers + cargo barrier, LongRanger 21lt water tank, Rhino Rack, Airtec Snorkle, ARB Compressor, Polaris Awning, DP Chip, 2.75" Beaudesert Exhaust, 12000lb Runva Winch
          • #80
            I'll see what I can do. But it may not be straight away. I have some leave and I reckon driving it might be better than photographing it.
            Regards
            Garry
            • #81
              Here we are,
              336000km on the clock, original springs and shocks.
              Front bar fitted
              Duel batteries.
              Tank filled to the max
              front 742mm
              rear 773mm
              So, what you guys reccon for such a 'cruiser with starship miles !
              Highest bungee jump in the world.
              [url="http://www.youtube.com/watch?v=OxxTDQzRrkU"]http://www.youtube.com/watch?v=OxxTDQzRrkU[/url]
              • #82
                good to see she is still going with a few miles under her belt, as for the suspension might be time for a well due birthday, it must handle like a boat with original stuff under it.
                • #83
                  OK just had ARB Deluxe Winch bar installed, with IPF driving lights, snorkel and OME with polyairs. Measurements are with tank near full and no weight in the back:
                  BEFORE:
                  Front (R) - 745 (L) - 740
                  Rear (R) - 765 (L) - 765
                  AFTER with 6psi in polyairs:
                  Front (R) - 787 (L) - 784
                  Rear (R) - 832 (L) - 832
                  OME setup is FRONT: OME884 and N201S with REAR: OME895 and N142. Polyairs to take the load when needed to boost the 895 towards the HD 896s....
                  Pretty happy with it today will see how it settles of the next month or so.....
                  Brett
                  '07 Prado GXL D4D Auto, ARB Deluxe Winch Bar, Snorkel, IPF Spots, UHF, OME 2 inch lift, Street Legal Window Tint and alot more items on the wishlist
                  • #84
                    on monday i fitted raised OME 885 (101-150kg load - heaviest OME do for 120's) springs.
                    i had ironman deisel (heaviest they do for 120's) raised front springs.
                    my shocks/struts are billies (perfect).
                    i did this because i was not happy
                    with the sagged height with the ironmans in the front.
                    the rears are great.
                    so replaced front (745) and got 775mm DS and 785mm PS (bottom of rim to guard).
                    had a closer look and thought i could inprove down travel.
                    took them back out and replaced rubber bush under hat (strut top) with a 10mm thicker bush.
                    re-assembled and measured.
                    got an extra 10mm down travel, happy days..
                    whilst i had it out a took some measurements to make a spacer
                    to go between hat and chassis.
                    still not completely happy with 775mm, so i'm making a spring spacer/packer, to go between
                    spring top and hat.
                    12mm extra pre-load on spring should give me a bit more.
                    after doing this i gave the body a small lift off chassis (see 120 modifications section).
                    so more lift to come in the near future.
                    now the front tin toyota bash plate doesn't have to work overtime.
                    [url=http://www.fuelly.com/driver/damonat/prado][img]http://www.fuelly.com/smallsig-metric/50578.png[/img][/url]
                    • #85
                      2008 Grande D4D - mine seems have been delivered with a higher rear than earlier model Grande's posted in this thread.
                      As new (no accessories):
                      Front 745
                      Rear 800 (on normal ride setting)
                      With Auto-Craft Ridepro/Bilsteins front & Bilsteins rear (factory air-bags remain)
                      Front 775
                      Accessories added to front at same time as suspension: ARB Bar, Winch, Dual Batts, XGTs.
                      Haven't measured with the low/high ride setting yet.
                      2008 D4D and a very long dog
                      [url=http://pradopoint.com/viewtopic.php?f=38&t=5318&p=74777&sid=afe8667706bc76d907c8fa81464352d4&sid=1d0b38233e6e0a28f012b5561ec1d59e#p74777]Our Prado[/url]
                      • #86
                        i have a 2008 GX D4-D 6 speed manual, with No accessories on it at all and the 3 row dickies are still in. it has 1500km on the clock.
                        front measures 750mm
                        rear measures 765mm
                        i will be putting in some OME soon. FYI, all front Prado coils have the same spring rate, only the free height of the coil changes. Prado coils are also used on the new hilux's for more lift over Hilux OME coils. i will post up what i plan to put on when the time comes. at this stage, I'm trying to find a replacement OME rear shock that will fit the Prado but has longer travel. ie, i put XJ jeep front shocks on the rear of my Suzuki vitara. still OME, but heaps longer travel. i'll post up my findings. also, OME are using a new steel for their coils which are better than the old steel they use. new steel is denoted by an 'X' before or after the part number on the coil box. OME also have another strut available, a N201S which is the super heavy duty ones for people with the lot up front. the other thing thats new with OME is that they are developing a series of new shocks and struts which will be the OME 'Sports' range.
                        SIK-120
                        2008 Toyota Prado 120
                        • #87
                          Just got the bog standard on my 07 GXL, 36k on the clock
                          (Sovereign Alloy only weighty thing )
                          Front - 740mm
                          Back - 780mm
                          want lift....
                          • #88
                            Hey gents,
                            just had the Billstein platinum package installed on my GX V6,not carrying much weight,Sovereign alloy bar,Toyota towbar.
                            Measurements taken by ARB in workshop before and after match my own within 1 to 2mm.
                            BEFORE
                            FRONT PASSENGER: 745mm
                            FRONT DRIVER: 745mm
                            REAR PASSENGER: 790mm
                            REAR DRIVER: 795mm
                            AFTER 2''LIFT
                            FRONT PASSENGER: 818mm
                            FRONT DRIVER: 820mm
                            REAR PASSENGER: 845mm
                            REAR DRIVER: 850mm
                            Not much fuel onboard at time but still pretty impressive!
                            Changing from Highway tyres to Cooper STs AFTER above measurements were taken adds another half inch or so again!
                            Will have another look in a few months after suspension settles.
                            Just out of interest,took some before/after measurements from underside of sidesteps front and rear, with lift and tyres installed,gained 70mm front and 75mm at rear.
                            P.S. Forgot to mention the Polyairs at 6.5psi
                            Daz
                            04 GX V6,Billstein/Ridepro 2''lift,Polyairs,7.5''alloys,Cooper STs,GME 3220 UHF,MIO GPS,TJM portable compresser,
                            Sovereign alloy bullbar,Toyota towbar/steps.
                            • #89
                              bottom circlip groove ?
                              • #90
                                yeah Darren,definately bottom circlip groove,I checked when i recieved them and after i just read your message I went out and checked to make sure they hadnt changed them before installing! measurements do suggest slightly more lift on front. Should front and back get the same amount of lift? Im only running alloy bar and 2 spotties on front,no weight in back. Very happy with amount of extra height but are these measurements unusual?
