ironman lift kits
  • #91
    Yeah as you can see it sits up pretty high. This pic is taken on a forward sloping beach too not level ground.
    Measured up today, 4 days after the fit
    FRont right. 823mm
    FRont left. 820mm
    Rear left 832mm
    Rear right. 835mm
    Black mica 06 D4D GXL. , kitted out to take me where we need to go to feel free......
    • #92
      This seems a fairly decent lift for 2 inches!
      • #93
        I reckon if you intend to load the front up....then it may likely settle down a fair bit like mine did
        • #94
          Ok did you leave the 15mm spacers in? I'm thinking twice about taking them out now as they seem to be in proportion the the rear. The prado seems to sit level, not nose down which is nice. Ill see how it looks when I get the new tyres fitted tomorrow. Still got my 265/65 cooper ATR on. Getting new BFG AT fitted tomorrow in 265/70. Should make a difference. Cheers
          • #95
            FRont right. 823mm
            FRont left. 820mm
            Rear left 832mm
            Rear right. 835mm
            That looks like a 3" lift. I would be concerned about CV angles.
            • #96
              It's a 2 inch kit with the spacers still in. Te tyres make it look big. I'm gonna wait a week or 2 to see how much it settles, if its still high than 800mm in the front in a few weeks, ill get the spacers taken out........or buy a steel bar.... Hmmmm
              • #97
                I based my comment on your measurements. A steel bar won't bring it down 1" since you are removing an alloy bar to put a steel bar.
                What size are the spacers?
                • #98
                  15mm spacers. Most lifts settle around 10 mm too.
                  • #99
                    The 15mm spacers would explain the ~30mm extra height you got. What does you CV angles look like?
                    • There's a bit of an angle. Not too radical prob about 30 degs. I'll take a pic. Looks pretty tough how it is but I think if it was 10-15 mm lower ( no spacer) it would be perfect. I reckon I'll take them out Friday. Just to keep the cv angle neat. Plus the shock doesn't have enough down travel. I heard them top out over the speed humps in my beach carpark.
                      • Yeah might be a good idea for longevity. How much droop have you got currently?
                        Maybe get the spacer chopped down to half to get your happy medium ?
                        • The spacers that come with the Iron-man kit aren't for use with the Prado. From memory they are for the hilux only. I remember something about looking into this when I put my lift kit in. Spacers are illegal, but then what's not these days...
                          • Originally posted by flying.kiwis View Post
                            I am not 100% sure but I thought the spacer was to be fitted when installing struts on the new hilux?? Pretty sure they share the same part numbers. I fitted mine without the spacer and happy with how ballanced (level) the truck is.
                            I found this while looking around, pretty much what I got with my kit I think
                            http://www.ironman4x4.com/pdfs/acces...structions.pdf
                            So it says that you can use it but as long as you still have the downward travel.
                            Nigelh,
                            Other than the raised nose how do you find the new lift in the short time you have had it? First impressions meeting expectations?
                            flying.kiwis
                            2006 GXL 1KZ TD Manual
                              Nigelh,
                              yeah very plush. firm with no body roll. a little pitchy on undulated bitumen roads, i think on road the slower rebound/ spring rate of the standard suspension is maybe more comfortable but off road the clearance and articulation is really great. like i said very plush feeling set up. Ive had EFS shocks and springs in my 80 series cruiser and Dobinsons coils, EFS shocks in my 76 series and i think the Ironman is actually better. The best ive ever driven is a GU patrol that had OME fitted but i think the Ironman is just as good. well worth the money so far.
                              • This feedback is pushing me more towards the Ironman kits.
