Bilstein/ lovells combo 4wd direct
    Originally posted by Hpycmpr View Post
    It would be worth your while contacting John form Zordos who has posted in this thread, he supplied mine (dobinsons bilsteins ) combo. Being a tight arse, I rang everywhere for prices he was the best even freighted from qld to Vic. I fitted myself, the back is fine but the front is a bit of a pain, and you will need access to a spring compressor.
    Perfect!! Thanks mate!! John it might be a tad late to contact you tonight but will give you a bell tomorrow! And rack your brain :-)
      I've got the Bilstein/Lovells setup.
      Front Springs TFR118
      Rear Springs TRR119
      Front Height: 770mm bottom of rim to guard (spring on bottom clip of shock)
      Rear Height: 820mm bottom of rim to guard
      The before heights were 735mm front, 770mm rear.
      I'm very happy with my setup. When I put a fully loaded trailer on the back, the car still rides level without air bags. The ride is nice and firm but not uncomfortable.
      If you've never worked on suspension before, it might be easier to pay to have it done. You'd be looking at 1 hour for the rears and 2 hours for the front. With a wheel alignment you should be able to get it done for around $300.
        Rear Springs TRR119
        Thanks for the info Gxl, much appreciated.
        Ghost
          Final decision made, John from zordos sorted me out new bilstein/ dobinson combo is ordered :-) thanks again guys!
            Picked up my dobinson springs today from the freight company!! Hopefully will get a call in the next few days letting me know my billies are here :-)
              Hi "ghost"
              You may have already posted this but I don't seem to see it....exactly what were the part numbers of the dibinson springs and bilstiens you have ordered....thanks
                Hi, brogers, sorry mate na haven't yet, but here they are
                Ended up going:-
                Front
                C59-302 60-100kg
                BE5A712
                And rears
                C59-327 100-300kg
                BE5A713
                I'm also going to be adding rear drawers and a winch soon.
                Craig
                  What weight was in the rear to go sd ? How does it sit now
                  02' Prado GXL 3.4L V6 - 2'' Bilstein/Lovell HD lift, Pacemakers + Hi-Flow Exhaust, Safari Snorkel, ARB Deluxe bar, IPF 900XS, Outback Drawer System, GME 3220, Dual Batt, 40L Engel.
                    With a full tank of juice the measurements are
                    Front 810
                    Rear 840
                      Ended up going:-
                      Front
                      C59-302 60-100kg
                      BE5A712
                      And rears
                      C59-327 100-300kg
                      BE5A713
                      Craig
                      Nice choice, and a nice ride height of 810/840. I think you'll be happier with the Dobinsons springs. Is that with the circlip on the front spring seat of your Bilsteins at the bottom (factory) setting?
                        Hi Peter, yea I'm stoked with how it drives, mackayvx took her for a spin the others day and was impressed, and yea for the moment the circlip is in the 1st position (factory or bottom) on the front struts
                          Front 810
                          Rear 840
                          WOW... I wouldn't mind those sort of heights....
                          I went with the Lovells Coil & Shock combination
                          Front Springs TFR118HD
                          Rear Springs TRR119
                          Lovell Shocks
                          And I didn't get anywhere near that lift....
                          my height is:
                          Front/760mm
                          Rear/800mm
                          I definitely need a greater lift, especially in the Front end for clearance
                          • #28
                            I was talking with 4wd trekmaster here in BNE when I was thinking of going with a Lovells kit on the 120 after having such a good run with them on the 90. He advised me that Lovells have never really gotten it right for the front end of the 120 and everyone he's fitted have been unhappy with the height.
                            I took that onboard and ended up with a Billies/Dobinson setup. Very happy with the lift and ride.
                            Cheers, Leon
                            Optix Photographix
                            • #29
                              Do you know what sort of heights you started off with rob_mac?
                              • #30
                                These measurements were when the car was NEW:
                                LHS: Bottom of Rim to Guard 786mm (Rear) // 755mm (Front)
                                RHS: Bottom of Rim to Guard: 786mm (Rear) // 760mm (Front)
                                Suspension height measurement - with STD suspension & with ARB Bullbar installed:
                                LHS: Bottom of Rim to Guard 786mm (Rear) // 745mm (Front)
                                RHS: Bottom of Rim to Guard: 786mm (Rear) // 745mm (Front)
                                Suspension height measurement - with 2" LOVELLS SUSPENSION with ARB Bullbar installed:
                                LHS: Bottom of Rim to Guard 830mm(Rear) +45mm // 775mm(Front) +15mm
                                RHS: Bottom of Rim to Guard: 830mm(Rear) +40mm // 785mm(Front) +20mm
                                Now after our outback trip:
                                Front-760mm // Rear-800mm
                                Happy with ride, etc, but not happy with the height now
