I pulled these numbers from various places here on Pradopoint, so they prolly include bullbars in some cases.
Note that the only 885 coil I have in the plot has almost 2.4" lift!
I tend to use 770mm for the rear, but it is usally somewhere in the 770-780mm range for a factory rear end.
Best
Mark
Yes the figures are right but why when a customer walks in and asks for a 2" lift but instead you give him a 1" lift at the front and close to 2" lift at the back and calling that acceptable is beyond me.
Matt call ARB head office and try and track down Sam who sometimes posts on here. Scream blue murder about how you have been treated.
May be last resort as I've emailed oz head office and then QLD head office rang me back. I now have to put up with it or pull the coils out. I just don't want replacement coils anymore Need enough info to warrant a refund so I can go elsewhere . Maybe the problem is I haven't screamed but that's not my style to carry on like a pork chop.
Leave a comment:
Guest
Guest replied
No real difference to swapping tyres on the road. The wheel that is ready to go on is right beside you so you would just do a remove and install in a minute. A 1/2" cordless impact driver helps.
Yes. Basically I work out where the spare tyre needs to go (position 1). Then take off position 1 wheel. Then work out where that wheel needs to go (position 2). Take off position 2 wheel. And so on.
No worries, I guess I'm just so used to doing it the way I do I can't see the obvious! I guess it's just the safety side of me wanting to make sure no one has an accident, vehicles are heavy and hurt when something goes wrong.
So you only have one wheel off at a time? And don't do anything else while the wheel is off?
I've only ever used the trolley jack for a 5-tyre rotation.
I find the handbrake usually needs adjusting when rotating wheels, and I'm usually fiddling around with something else at the same time. You could probably get away with two stands (one pair) if budget was a big concern. I would prefer one pair of good stands than two pairs of crappy ones.
Hey Matt, I personally would go for a slightly better jack. Buy a good one once and it will last the home workshop a lifetime (well a very long time at least). http://catalogues.repco.com.au/catal...30413#pageNo=8
The one at the top of page 9 for $159 is great, it's actually the one I'm using for work at the moment. You will find with a lifted 4wd the little ones can run out of travel before you get it high enough.
Snap
You will need 4 stands to do a wheel rotation too, never work on a car without stands!
I'm guessing you are looking at the 5 peice workshop kit they have on sale at the moment for $79.99, everything in that kit will technically work, but really is underrated for a heavy 4wd. I can't imagine the jack lasting very long even in a home workshop, and you will curse at the amount of effort required to use it and avoid doing the wheel rotation.
I personally prefer pin type stands, they are much more positively locked compaired to ratchet type ones and cheaper for the same quality. You will need 4 stands to do a wheel rotation too, never work on a car without stands!
Edit: The load rating on stands is when used as a pair on a hard level surface and evenly loaded, I bet your prado weighs over 1.2T over the front axle as you jack the back up. You always need plenty of head room when talking about safety equipment
Edit2: Damn you Andrew, posted while I was trying to get links. It is a great Jack
Hey Matt, if you come to the conclusion the springs are crap (looks like they are no good for your setup) let me know. As long as you have flat concrete at your place I can come down after work one arvo and we can get stuck in. I'll bring the work ute with stands, jack, tools, etc. even being the scan tool and we can have a squiz at those injector values. Let me know mate, happy to help out after you have been screwed buy one of our lovely suppliers up here.
Pradopoint is great .Im Feelin the love. So much help offered from Whitey trying to learn me on suspension and people like Andy who we chew the fat with on steak night . People helping people out . Thanks Andy ill pm you mate. Will have to get my values checked soon. I'll get this droop checked first I think on the weekend. Talk soon .
Matt
Got a set of stands you can borrow Matt if you're not ready to buy a set just yet..
Thanks Craig , however this may be a case of this is something I need to buy wifey! I'm going to have to rotate my tyres soon soon so these will be handy . Saw this at supercheap. Is it to cheap & nasty? If the prado weighs about 2t and these stands are 1200kg each & I only lift the front or back at one time and use 2 stands I should be ok? Trolley jack ok being 1200kg?
Edit : well that didn't work http://m.supercheapauthttp://www.sup...5-Piece/358257
Leave a comment:
