Mine fitted today,, Gotta have a shower and pack up my tools!. Will do a write up tonight and post some pics,, Drew's write up and Chippys step by step (on a private PM) were unreal !!!
Matt :lol:
Why a private Message - Share Share Share
08/06 Build GXL V6 Petrol Auto, Charcoal Grey, Sovereign Bar, Bilstein/Lovell 50mm Lift, Duel Batteries, DVD Headrests, ARB Air Under Bonnet
Yeah, rather than annoy everyone else with the banter we tend to rabbit on like a CWA meeting on PM.
If anyone wants the detail posted here - and Matt doesn't still have a copy - I'll whip off another set. It's just a boring set of text instructions 'cause it pissed down the whole day and my camera didn't like getting rained on and stopped working. I don't mind sharing but I like pics more .. and I was a bit pissed off that I didn't have any. ops:
Well done Matt. Adds well to Drews pics and install notes.
Makes me feel guilty having after having paid to get them fitted ops: ops:
Took Moo out over the wekeend and the Poly Airs have pretty well stopped the sag in Angus' bum when Moo's hitched on (keep ya mind clean boys) :twisted:
Angus sagged nearly 30mm without the Poly Airs so I'm happy.
PeteS
The middle hole, in the picture below, is the 13mm hole that the airline passes through and it fits quite nicely - even with split tube over the airline.
The instructions, that come with the polyairs, say that this hole needs to be enlarged with a 40 mm hole saw. :shock:
For starters - even with a 40 mm hole saw I couldn't get it to start without a pilot bit that was a fairly snug fit in the existing hole ... and I don't have a hole saw with a 13 mm pilot bit. There's also a bit of body pressing hiding up behind that plate so the pilot bit would have to be set fairly shallow or you would punch a hole through it.
The airlines fit and the polyairs work fine - without enlarging this hole - but I'm still curious - does anyone have any better ideas on how to do this ?
Chippy,
I concluded that this was a waste of time. I think they might have copy/pasted some instructions from another vehicle. Just my 2c.
Drew.
2005 Toyota LandCruiser GRJ120R Prado "Pilbara" (GX+) Petrol V6 5 Speed Auto, ARB AirLocker rear diff locker, Safari Snorkel, Bilstein Shocks, OME 2" Lifted Springs, PolyAir airbags, bash plates, Icom HF Transceiver, Uniden UHF CB, HID and LED lights, Black Duck seat covers, Tekonsha Prodigy trailer brake controller, Redarc Dual Battery Controller, ATS4X4 Side Steps/Rock Sliders.
Hey Drew
I read your notes and assumed the same thing - that and the fact that your notes made more sense - I also passed the same info on to Matt for his fit up.
Nice job and photos Matt.
Just a small point you should be able to remove rear springs by undoing
14mm sway bar connecting bolt. Dropping bottom shock mount bolt and using longer jack stands. (place normal jack stands on some bits of 4 b 4. or some sort of safe platform) Lower the diff down and the springs will fall out, just watch that you don't go too far and damage the brake lines.I would hate to here of some one hurting themselves by placing jacks in between diff and chassis.
Might have to fit them to my prado as they don't take much load to sag in the rear. I have 2 fridges in the back, beer and other drinks for 4 weeks
boat on the back.... and 4 lights pointing in the air :roll:
Cheers Phil.
[size=1][b][i]07 D4D GXL PRADO 6spd man.[/i][/b][/size]
[size=7][color=blue][i]BFG AT tyres 265/70/17,55mm ATS suspension,tow safe tow bar,Mine Trans seat covers,sandgrabba mats, 60 Litre Engel fridge,front tint,safari snorkle,arb deluxe bull bar, Hella HID lights,760cca dual battery setup,uniden uhf cb, and more to come !![/i][/color][/size]
'The appropriate kit for a lifted 120 has part number 12995, and are the same price as the standard kit, part number 12895.' I assume this is a genuine PolyAir part number.
A mate of mine got a set of 'Air Lift 1000 Air Spring Kit'
for his Cruiser, $70 a set plus a bit of freight delivered to his door from the States (from memory about $40 to $50). This is the link.
I was wondering what the equivalent set for the 120 would be (as in part number). Any ideas? Mate reckons the 120 is sold as a Lexus in the States??
The part numbers I quoted are the Polyair numbers.
The 120 is kind of sold in the states as a Lexus GX. See http://www.lexus.com/models/GX/ It's a different spec though with a V8 engine and a slightly different body. The FJ Cruiser and the 4Runner also share similar components to the 120. See http://www.toyota120.com/
Drew.
