265/70 17. Probably cheaper you to buy some 17s with 10 or 15 offset and new tyres at the same time!
Bf Goodrich Ko2
Yeah I looked into that - if I went for a basic set of steel rim it might be, but for something decent it's not, and then there's all the hassle of correct offset, not fouling the KDSS sway bar etc. Other users on this forum are running Hilux or FJ Cruiser 17's, but they're $$$.Originally posted by mjrandom View Post265/70 17. Probably cheaper you to buy some 17s with 10 or 15 offset and new tyres at the same time!
David.[SIZE=2][U]2012 150 Series D4D Kakadu[/U][/SIZE]
[SIZE=1]Wynnum Towbar, Narva Merit/USB/lighter sockets, Pirahna dual battery tray, Redarc BCDC1240, Xantrex LinkPro battery monitor, 600W inverter, ARB onboard air & WaterWatch on AMTS bracket, Phillips 35W HID high beams, UHF, Roadsafe front recovery points, Offroad Systems drawers with integrated water storage with tap concealed in rear tailgate, ARB 47L fridge.[/SIZE]
Jax Essendon $330ea. 265/70-17.Originally posted by RobboPrado View PostOK am getting the KO2s next Saturday. It was funny as rang Bob Jane (quote was $375) as they have a best price guarantee and if you show them a quote under theirs they have to meet it and pay 10% back to you for the difference. Well after twice calling and they promised to ring me back, they didn't
Tried Beaurepaires and they were going to charge me $410 a tyre fitted and then $60 on top for an alignment! K-mart quoted me $370, Tyre factory $350 and the one with the best price was Canterbury tyres - $348. So it pays to ring around, I will save about $400 on buying 5 from the cheapest compared to the most expensive quote.
Now does anyone want 5 Dunlop Grandtrek A22s going cheap, excellent condition??
Tell Angelo you are from the Prado crew.
New to 4wd so have a question, if I have a 2 inch lift and standard rims, what is the largest tyre that I can fit without rubbing. I know that the speed will change depending on the tyre size, and that I will need a 20mm spacer for the 5th tyre, does anything else need to be considered. I am looking at the KO2 to replace my current set.
265/70 are the way to go. Definitely no rubbing with that set-up. Your speedo will also read 100% accurate with this profile like mine.Dave
The speedo accuracy will depend on the year, after late 2006 from memory 70 series tyres will correct the speedo, earlier models the speedo was dead on, so larger tyres makes the speedo read slow, so you need to be careful.Originally posted by Bushbasher View Post265/70 are the way to go. Definitely no rubbing with that set-up. Your speedo will also read 100% accurate with this profile like mine.
I found some bf ko2 in 265/70/17 for $309 fitted from Tempe tyres. I realise that they are probably grey imports but can anyone see a downside to getting it from them at that price. Most other places around near me are selling it for $350+. So a $200 saving as I'm looking at getting 52008 Prado 120 GXL V6 auto. Stock...but slowly building it up
Be aware some places charge a disposal fee on tyres.Originally posted by ravenhard View PostI found some bf ko2 in 265/70/17 for $309 fitted from Tempe tyres. I realise that they are probably grey imports but can anyone see a downside to getting it from them at that price. Most other places around near me are selling it for $350+. So a $200 saving as I'm looking at getting 5
I got mine from Bob Jane for $335 fitted.2010 150 gxl D4D with ARB delux bar, towbar! Custom DIY drawers, rhino HD bars, 2" Dobinsons, platform rack, IPF lights and BFG AT2 and extras
Be aware that BFG AU won't cover warranty on tires sourced from non-official channels. I found some cheap on eBay too but the seller was honest enough to mention this when I queried the warranty status.Originally posted by LargeInAPrado View Postthey are all imported Ravenhard so there should be no issue.
After all I'm yet to hear people chasing 'warranty' on BFG's
You would go back to Tempe Tyres for warranty claims. Handy if you are local.Originally posted by ravenhard View PostI found some bf ko2 in 265/70/17 for $309 fitted from Tempe tyres. I realise that they are probably grey imports but can anyone see a downside to getting it from them at that price.
I bought from Don Cornell tyres and warranty will also need to go through them. Tested this out as the tyres arrived at the courier depot with damaged beads. I guess this is a pretty clear open and shut case, but they sent a new tyre after requesting for photos of the damage. So far pretty good experience with grey imports.
