Went and bought some bits I needed to install the control box today, split tube and bolts, etc. Looking at the box today I noticed the cables aren't completely tucked into the rubber boots where they enter the box, there's a little bit of copper showing. I had the cables replaced with longer ones by the auto electrician down the road, looks like the cable he used was just a bit too thick for the cable and insulation to fit in the rubber boots together. I'm not too happy about it as I can see water getting in the cable and/or box that way. I'm going to open it up and see how hard that will be to fix, can't see any other way short of heatshrink tube to seal the gap. I'll be taking it back if I can't sort it out myself, after all I paid good money for the job.
On the subject of opening the control box I was going to beef up the seal with some silicone or there was another product I can't recall the name of (Red something). Are there any other preventative measures I should take to protect the control box from water ingress?
