Redarc Tow Pro for 2017 Prado
  • Redarc Tow Pro for 2017 Prado
    Has anyone fitted a Redarc Tow Pro trailer brake controller to a later model Prado?
    I have a new 150 and need to fit this soon.
    Any suggestions appreciated.
    Follow the instructions they supply, pretty easy and foolproof
      I installed a 'classic' Redarc controller in my 2012 Prado 4 years ago. I installed the adjustment knob to the right of the drivers knee but I always kept hitting it, getting in out. So I put it in the centre console near the usb port. I found that the ideal place because you could find it without looking. It's also an easy position to install the wires by simply uninstalling the glove box and passenger side kick panel and tucking the wires up under the left hand side of the centre console.
      I've just ordered the the 2018 GXL with the leather upgrade and heated seats and noticed there is no port in the centre position any more. I'll be installing a tow pro elite when I get it.
      Therefore I'll need to find a new position for it when it arrives in Jan. Hopefully a position I don't need to look for it while driving. I know its all automatic but its nice to get to it quick. I only carry a Malibu ski boat behind for towing.I've been told, with electric over hydraulic brakes that the tow pro works better in manual mode. I don't know how true that is but I'll find out soon enough.
      When I installed the classic model , I ran the the positive and negative wires straight to the the starter battery (don't forget the CB) and then run the trailer and brake wire straight to the trailer pin. I can't remember if I wired it in prior the ECU or straight to the pin. Saying that others have sent the brake wire to the brake pedal instead but make sure you get the correct wire. I think i 6mm wire was what was recommended. Also remember with the tow pro that the unit can't move so it needs to be firmly installed. I've seen installations using strong double sided tape but I'm unsure on how effective that is. I'd be interested to hear others opinions as I'll be fitting a tow pro elite very soon. I hope that helps
        This is pre facelift. Easy install. Pink or purple wire off brake pedal. Everything else as per instructions.
          Make up a small mounting plate and mount it up under the steering column, there is a threaded hole on it.
          A piece of gal sheet metal with four nutserts and a hole drilled for mounting (nutsert gun from AutoOne $60).
          I ran the Sidewinder brake harness kit to the rear.
          Buy the switch bezel from Redarc instead of modifying the original.
ID:	656494 Tow Pro Installed, there is a bracket near the steering column that you can bolt the unit to.
            Some excellent ideas there, thanks Halsey
              Reignited old thread. I’m about to install a tow pro elite and noticed that according to the instructions the brake signal wire should go down towards the trailer plug at the rear, but apparently a diode needs to be fitted to the original cable prior to where the brake signal wire gets spliced in. Has anyone done this and does it sound right?
              All other wires apear appear easy enough..
              thanks
              2016 Toyota Prado GXL auto. ARB deluxe bar, Rock Armor side steps, 9in Penetrator LED spotties (30,000LM), Uniden 8060 UHF, Bilstein/Dobinson 2in lift, 265/70/17 Mickey Thompson ATZ P3's, Safari snorkel, Dual battery system, ARB onboard compressor, Custom rear false floor, Kaon bash plates, Ext. diff/gearbox breathers, Provent 200, Wynnum tow bar, Roadsafe tow points, Phillips crystalvision bulbs, tint, Rhino rack platform.
                thanks
                Not sure what year yours is and if newer ones are different, but I fitted a towpro elite to my pre-facelift 2013 GXL, and didn't need to use a diode.
                Just spliced into the wire that was already there waiting to be used.
                All seems to work perfectly.....
                  Rascal where abouts did you tap in ... I was looking at the brake pedal And the red wire is like before brake is pressed?
                  2018 VX Prado
                    Pink or purple wire.
                      Mine was a blue wire hanging around behind the LHR tail light. Just remove the jack compartment cover, and it was just hanging there unterminated, begging to be used.
                        Hey Rascal, did you end up figuring out if you need the diode? Ive got a Kakadu and dont want to risk sending 12v back up the canbus and blowing something expensive up.
                          No, I didn't need any diode. Just used that wire and all works perfectly.
                          Note mine is a GXL, not sure if that makes any difference..
