Fitting REDARC Brake Controller to GXL 150
  • Fitting REDARC Brake Controller to GXL 150
    Hi fitted a Redarc controller to my 150 , got the idea from Prado Point
    1- Finished Product [attachment=2:1n1tvoeo]P7230370.JPG[/attachment:1n1tvoeo]
    2- You need to remove Drivers and Passengers vertical trim , they pull out pulling from the bottom out[attachment=1:1n1tvoeo]P7220347.JPG[/attachment:1n1tvoeo]
    3-Pull the A/C panel out , found this best pulling from the bottom in a up motion[attachment=0:1n1tvoeo]P7220349.JPG[/attachment:1n1tvoeo]
    4- This is the panel to fit the led and knob , it does not pull out from the outside , comes out from the inside , there is a top and bottom to this insert
    5-Drill out the holes and cut away the inside plastic to mount the led and knob
    6- Mounted the box up here ,just under the metal tube
    7-Place some foam here so not to rattle
    8-Turned unit upside down and cable tied into place , wrapped from tape around the wires close to the box so they would not chafe
    9-The unit is mounted just inder the metal tube
    10-Inside the jack holder is the trailer cable box , held on with strong double sided tape , this is where I picked up the stop lamp and in the same wiring loom you will find a blue wire not connected this is the trailer brake wire.Ran 2 wires down to here , could have picked up the brake light up at the brake pedal but thought I stay away from the pedals .
    Caution: When wiring up the controller follow the wiring diagram , the red is not 12v and the white is negative, not what you would think ( saves pulling it all apart again when you read the instructions at the end after you have reassembled the car !!!!!! ) :roll:
    Have to thank Sidewinder for his posts that helped me gain access Cheers Digger
    White GXL 150 TD , Black King Rims with BFG , 40 l Engal, Thumper power supply, Tracklander roof racks,Maxx Tracs , Icom ic440, Redex Brake Controller, Factory towbar, Sidewinder trailer charging system, Rock Tamer Mudflaps and Hema Navigator.Camprite TL8S
    Re: Fitting REDARC Brake Controller to GXL 150
    Not Sure how to add more than 3 pic so here are the rest :lol:
      Another 3
        Last one :lol:
        Hope this helps , got the controller of Ebay and saw someones build and they have mounted it there and thought that was a good place for it , sorry for the 3 posts not that good on the computer . But have grabbed a lot of this site so with controller and camera in hand :lol: Hope this might help someone .
        Cheers Digger
          Nice install... well done.
            Nice job. Question, does the Redarc unit have a pendulum/accelerometer in it? or is it just static pressure?
            Thanks for the photos on dash dis-assembly, they will come in very handy
              Not sure on that you would have to look at their web site, my camper is not that heavy so went for a unit which could fit in the dash and not worry about knee knocking it or air bags . They came with a good wrap so went for it . Got it for $178 of ebay from Aust .
              Cheers Digger
                It doesn't have a pendulum / accelerometer in it but it is small and that's the reason i bought one too. Small,tidy brake controller. Hey digger i'm having a go at fitting mine tomorrow. Which way did you run your two core down to the trailer wire box? From the brake controller then down left or right hand side of the car?
                Geoff
                  Hi Geoff
                  I ran it down the passenger side , took of the panel under the glove box 1 screw, then the pass door step , then the pass kick panel, undo the knob looking thing at the front of the panel with 3 slots in it , it screws out then pull it out .then undo back pass door step panel first unbolting the step.I ran the wire around the door pillar and just pushed it into the trim. Also when you pull the door seal out up to the mid way after undoing the seat belt as per sidewinders instructions . I placed a hollow tube from the door gap to the jack space and feed a draw wire in them pulled the tube out then pulled the twin core to the jack space with the draw wire.This saved a lot of muching around trying to feed the wire into the jack space from the door side.
                  Make sure you follow the wiring diagram as red is not the 12v and think black was not neg ,m I had to rewire once finished opps :roll: Good luck
                  Cheers Digger
                    Hey Digger, Job all Done Thanks for the tips. Mine is a 120 GXL but i wired the same way you did. Heavy Duty two core down L/H side and picked up brake wire of the trailer loom near the Jack and the the "Blue" wire for the electric brakes. Fitted 50mm anderson plug beside my 7 pin round trailer plug and ran 2 B&S cables along L/H chassis rail and up to dual battery relay while i was going 8)
                    Geoff
                      Boys how do you rate the redarc? I'm thinking of doing the same
                          I find the redarc fine. It's a no frills system and good off road. Depends on your situation. The following I found using Google and has some good info:
                          http://caravansplus.com.au/catalog/h...ontrollers.php
                          Winston.
                          Winston.
                            Might be an updated model towards the end of the year, I'm hanging out as long as I can. Had it in my last truck found it good but a little annoying. Had to be working the dial whenever changing from dirt to tar or speed majorly. Ie driving on tar highway at 100 Km's I would have it on about 5 or 6 so it would help me pull up in a hurry, however if I slowed down & pulled on to some dirt without changing the dial the trailer would lock up instantly. Also the lack of any delay (especially when driving slowly) was a bit annoying.
                            Not trying to steer you away from the unit, but just be aware they are a basic unit. You can't beat the remote mount tho, very neat. If they don't end up bringing out an updated version I'll end putting the remote unit as currently available in. I only tow a camper trailer occasionally & a small caravan extremely rarely, so a basic unit is ok for me as my priority is a clean/neat cabin.
                              Pete you may be right but I asked the state manager for Redarc about an update or proportional unit and he said nothing new in the wings. I really like the remote arrangement but these units do have limitations as you have said.
