Hi fitted a Redarc controller to my 150 , got the idea from Prado Point
1- Finished Product [attachment=2:1n1tvoeo]P7230370.JPG[/attachment:1n1tvoeo]
2- You need to remove Drivers and Passengers vertical trim , they pull out pulling from the bottom out[attachment=1:1n1tvoeo]P7220347.JPG[/attachment:1n1tvoeo]
3-Pull the A/C panel out , found this best pulling from the bottom in a up motion[attachment=0:1n1tvoeo]P7220349.JPG[/attachment:1n1tvoeo]
4- This is the panel to fit the led and knob , it does not pull out from the outside , comes out from the inside , there is a top and bottom to this insert
5-Drill out the holes and cut away the inside plastic to mount the led and knob
6- Mounted the box up here ,just under the metal tube
7-Place some foam here so not to rattle
8-Turned unit upside down and cable tied into place , wrapped from tape around the wires close to the box so they would not chafe
9-The unit is mounted just inder the metal tube
10-Inside the jack holder is the trailer cable box , held on with strong double sided tape , this is where I picked up the stop lamp and in the same wiring loom you will find a blue wire not connected this is the trailer brake wire.Ran 2 wires down to here , could have picked up the brake light up at the brake pedal but thought I stay away from the pedals .
Caution: When wiring up the controller follow the wiring diagram , the red is not 12v and the white is negative, not what you would think ( saves pulling it all apart again when you read the instructions at the end after you have reassembled the car !!!!!! ) :roll:
Have to thank Sidewinder for his posts that helped me gain access Cheers Digger
