I had my wagon on the hoist today so I thought I would show everyone how I fitted the B&M oil cooler to it.
The mounting is bolted to the bullbar supports and is made out of 50/50/6 aluminium angle. The mount holding the cooler are valve cover isolators off "C" series Cat engines.
I plumbed it from the trans then back to the radiator cooler. The cooler has a thermostatic switch set to turn the fan on the cooler on at 95C and off at 90c. With this set up we are seeing around 15/20c lower temps
Sean
Sean
