Originally posted by Steve M
View Post
lockers over traction control
Not sure I follow your logic, wouldn't not having the wheel spin in the first place be better?Originally posted by scottkz View PostTRC uses the brakes to stop a wheel from spinning .... So if you have a locker one wheel shouldn't spin so theoretically TRC SHOULD be better than a locker but in practice I doubt it
From my experience I would say when the going gets tough lockers will out perform traction control, but not by much. The advantage of TC is that it's always there, so it will do it's job in those unexpected moments where you may not have engaged a locker.
TC works well with lockers. Tends to take a bit of load off the brakes. Brakes can get hot so if you are doing lots and lots of lumpy work both are a good choice. I'm pretty sure the reason I warped my discs in the 120 was extended rock hopping. I will be chucking a locker in the back of the 150.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Came across a video of the same prado attempting a climb with TC and again with Locker a while ago, but can't for the life of me find it. Did come across this which reinforces what most are saying. TC is good for most things, but not all, and has limitations (heat build up and loss of momentum). Locker and TC work really well together.
I don't have TC in my 120
http://www.outbacktravelaustralia.co...harrop-elocker[SIZE=2]120 GXL D4D Auto, with a 'List of Wants' greater than the 'List of Needs' greater than the 'List of Haves'
I have traction control (120 Grande). There is no way it comes close to letting me do what the lockers do.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Well the TRC shouldn't allow the wheel to spin at allOriginally posted by AJ120 View PostNot sure I follow your logic, wouldn't not having the wheel spin in the first place be better?
I think it has to spin a little bit, otherwise how does the TC know it needs to engage? From what I see the wheel spins maybe a 1/4 turn then the TC kicks in, the locker will eliminate any spin.Originally posted by scottkz View PostWell the TRC shouldn't allow the wheel to spin at all
I always think back to the 2011 GTG at Landcruiser Mountain Park watching 3 Prado's climb a rugged hill. Quicky in his standard 120 Just got up with massive wheel spin and huge wheel lift, Dobbo in his TC 150 got up relatively easily but was a bit jerky and it didn't sound good, Rev in his twin locked 150 looked like he was on a Sunday drive.
Cheers AndrewLast edited by AJ120; 11-09-2014, 07:09 AM.[COLOR="#FF0000"]So Long and Thanks for all the Fish![/COLOR]
Have to agree the traction control on my 150 is an awesome feature but it does have it's limitations. One being creek crossings and mud when the breaks are wet the TRC looses it's effectiveness, but apart from that it's pretty faultless. Low rang first gear at idle it will crawl out of anything !![SIGPIC][/SIGPIC]Prado 150 , 2010 VX Diesel Auto, TJM Airtec snorkel, 2" Lift kit, King Springs, Bilstein shocks, TJM T13 steel bull bar, Tigerz 11 12000lbs winch, DP Chip, 3" manta exhaust, Light Force HID lights, dual batteries, Red Arc management, Tyre Pressure Monitor System, BFG MT 285/70/17, uniden UHF radio, LED light bar, Scan gauge 2 secondary fuel/ water separator, B&M auto trans oil cooler, 45ltr Evakool travel Mate fridge.
Correct, no Crawl Control in the 150 GXL. Hi/Lo, centre diff and DAC are all you get at this level. Leads me to consider the Elocker option.Originally posted by fido666 View PostPretty sure the GXL does not have the crawl control feature even in the facelift models, it only comes in the Kakadu model.
