Originally posted by shonky 150
View Post
I looked into them and the data being supplied sounded just way to good to be true. But I bought a small number of them in different sizes and started testing them.
I am never interested in the advertising claims made about products intended for RV use, I just want to see if they stand up to the many claims made, when these products are used, and abused, in real world RV situations.
Well I have caned the crap out of all these Lead Crystal batteries and have not managed to damage one of them, and believe me, I have been deliberately abusing them.
Lead Crystal batteries have a number of benefits that makes them ideally suited for the RV market. One of their primary advantages is that they can be left in any state of charge, for very long periods and not have any detrimental effects, other than requiring a couple of charge cycles to get them back to full capacity. This makes them ideally suited for use as house batteries in camper trailers and caravans, that are left unused for long periods between trips.
The batteries are actually delivered with a sticker on them indicating when the battery was last charged, and some of the batteries I bought were last charged nearly 12 months earlier.
This one feature alone makes Lead Crystal batteries ideal for RV use, particularly for use as house batteries in caravans and camper trailers, that are left unused for long periods of time, between trips.
They are also “UNDER-RATED”, meaning they are actually rated at a lower Ah than they can provide.
Lead Acid deep cycle batteries have their Ah rated by testing at C20 loads, where as a Lead Crystal battery's marked Ah is rated using C10 loads. When tested using C20 loads, they are much better than equivalent lead acid batteries.
Another big advantage is that they can be CONTINUALLY discharge to 0% SoC ( 10.5v ) many hundreds of times.
I have been cycling a number of these batteries down to 0% SoC and then charging them with different recharge voltages and they can be easily fully recharged with voltages as low as 13.6v. I have not bothered charging them with lower voltages as yet.
I have had quite a few conversations with the owner of Betta Batteries and he has supplied me with a lot more info about these batteries than is found on the site.
Lead Crystal batteries can be charged with up to 800% of their marked Ah rate, for example a 100Ah Lead Crystal battery can be charged with 800 amps. I am not sure how you would achieve that in RV applications, but they can still be charge with an alternator at high currents and no problems of overcharging or over heating.
Again for example, I have been carrying out bench testing of these batteries, charging FLAT ( 0% SoC or 10.5v ) batteries using different voltages to see how well they can be charged in different vehicles, with varying alternator voltages and here are some of the results.
55Ah battery, charged at 14.0v, had a starting current draw of 47.4 amps and after 1 hour, was still drawing 20.8 amps.
70Ah battery, charged at 13.6v, had a starting current draw of 53.2 amp and was still drawing 31.4 amps.
NOTE if you need faster charging, then an Optima Yellowtop is the way to go, but if you need larger battery capacity, Lead Crystal batteries are a much better choice over AGMs and they have near the same cycle rates as lithium batteries, but at a fraction of the cost of lithium batteries.
<removed by admin>
Leave a comment:
