Nice work ! What voltage is you setup registering with the diode?
I went same route with a diode and isolator but have pulled the diode a few months ago. The voltage output seemed very high at times and was reading 14.6v every now and then. What is the ideal voltage charge level for charging the battery? Without the diode the vehicle is now charging minimum at voltage of 13.6 with the diode is sitting at 14.2-14.4v. (2010 GXl Diesel)
This is a sticky topic.
Nice work Marky, I doubt you'll have to much criticism on here as you appears to have done all your homework well! - the only thing you have forgotten is to post up some pictures of your handywork...
Leave a comment:
Hi all
Thanks for all the info in this thread! I've just put a second battery in my 2011 GX (3.0L diesel) and thought i'd post what i've done for those interested.
- Put in one of LeighW's booster diodes (worked as it should).
- ARB Battery tray.
- Got someone to move the air con pipe and put in a new bracket for it.
- Isolator from Drivesafe, the new DT90. I had one of his old isolators in a previous car and it worked well so I went with what i know. It's SUPER easy to install, even for a complete auto-electrical novice like me.
- Platinum series 85Ah battery (dual purpose, starting and deep cycle. It was a good price so I figured i'd give it a crack).
- I ran the cable from the DT90 into a fuse block hidden in the rear storage area which then runs into two cig plugs. There's a nice little space underneath the cup holder to hold the fuse block and store all the cabling.
All up took me the most part of a day to fit it but that was with plenty of procrastinating.
Initial circuit testing looks pretty good but yet to give it a proper test (ie. to keep the beer cold...) My needs are simple, to run a Waeco 50L fridge and a few lights and maybe a swag fan. The wet season in the North is really brutal...
Happy to receive constructive criticism from those who know better, as I said I'm a complete rookie! Can post photos if anyone's interested.
Leave a comment:
In the process of installing dual batteries in the V6, and after reading up on Pradopoint, did the usual voltage checks to find it too was charging low. Put in an order from LeighW and a couple of days later, with a Booster Diode doing its thing, alternator voltage output is now at a more satisfactory level. Happy as.
Leave a comment:
1. Not usually
2. Yes
3. Maybe...
DCDC will do the job but it depends where you mount the battery and auxiliary. Plenty mount under the bonnet but the DCDC needs to be cool. A VSR will also do the job but be wary using these and dissimilar chemistry batteries (like AGM or lead crystal), not all work together nicely.
Read through this thread and the pre update thread. Decide if you battery is living under the bonnet or in the car (mine is inside). Then choose a battery. Then pick a charging device. Then wire up as per manufacturers recommendations.
Then run an adequately sized cable to the fridge location.
Leave a comment:
Hi all.
We have just bought a brand new 150 Prado and need to put a dual battery in it for the fridge.
How has Toyota wired up the vehicle?
Is it that the two batteries are directly connected to form one large crank battery?
or
Do I need to put an isolator in for the second battery?
or
Do I need to put in a DC Charger (I have a Redarc BCDC 1240)?
Leave a comment:
You cant go wrong with a yellow top - and LeighW's booster diodes if you have the 3L.
You can use almost all of the 66AH and it'll take on the recharging as quickly as anything.
Leave a comment:
Hi All,
Just thought Id revisit this thread given that some of the info is now a couple of years old.
Ive been trying to see what dual battery everyone has been putting under their bonnets these days. Is there anything new on the market or are the yellow tops still getting the nod?
Ive been very happy with a 105ahr fullriver that Ive had for a number of years but it is both too heavy and too long to fit up front.
My choice will be paired with a redarc SBI12 which I have had for a number of years now. Simple setup running a 40 L Engel and a coupla LED lights with mainly weekend trips and maybe a 5 week trip on occasion with plenty of driving every few days.
Heading to the Perth 4WD show next week so will see what sales pitch wins me over unless I hear some convincing information on here.
cheers
Leave a comment:
Recently had some oil leaks fixed under warranty and in the process, Toyota dealer had to disconnect the AC plumbing. This caused a bit of a fault as when switched to AC, heating didn't work. Anyway, dealer was great and fixed it straight away, no charge but discovered something very interesting.
Noticed that I suddenly had a lot more clearance between the AC pipe and my battery than I had before. See my earlier post #418 for pictures and compare with today's photo. The AC pipe is now straight up and not bent. Heaps of clearance. Have they bent the pipe or fitted a new pipe? When I compare the before and after photos, there is definitely more clearance now. Whatever they've done I'm happy with it. And no, they haven't moved the ARB battery tray that the optima D34 is in.
Leave a comment:
hey might of missed something here...Originally posted by drivesafe View PostHi again Ghandi, try disconnecting the auxiliary battery, and you can do this by simply removing the NEGATIVE ( - ) terminal clap on the auxiliary battery.
Then connect the battery charge’s positive lead to the cranking battery’s POSITIVE ( + ) terminal.
Next, connect the battery charger’s negative lead to a good earth point in the engine bay.
Do not connect the battery charger’s negative lead to the cranking battery’s negative ( - ) terminal.
Even though the charger should be off, it is best to get into the habit of never connecting to the cranking battery’s negative ( - ) terminal for charging or jump starting, for safety reasons.
NOTE, you do not have to disconnect any of the cabling connected to the cranking battery, just charge it in place.
The higher RECOND voltage of 15.8v will not effect any of the vehicle’s electronics but also make sure the ignition is turned off AND THE KEY REMOVED.
You need to remove the key because quite a few vehicles now days, power up some circuit while the key is in the ignition but not turned on. Otherwise the charger will be trying to charge the battery and power any circuits that may be live.
Where do you put the ignition key if a 150???
Leave a comment:
Leave a comment:
Thanks everyone, will just leave it on overnight every month or two, to give the batteries a good top up (don't have a booster diode yet to nicely charge both batteries.)
I would also like to recond the cranking battery as it came with the car when I bought it and unsure of its history. Looks like a basic cheap battery, maybe even original OEM?!
Recondition the battery is recommended every year or so with Ctek. Does that sound fair? Doing that and topping up every so often will extend the life and maximise efficency of both batteries?
Leave a comment:
Hi Ghandi, just connect the charger to your cranking battery and leave it to do what it is designed to do.
As for the settings.
If both of your batteries are wet cell, calcium or otherwise, you can use the reconditioning mode.
As for it being “PROBABLY SAFER” to use the lower setting with AGMs.
If either or both batteries are AGM, under no circumstances should you use the RECONDITION Mode.
If you try to charge AGMs with any voltage over 14.7v, you will destroy an AGM type battery.
Leave a comment:
If your goal is to charge both, then putting the charger on the cranking battery and letting the SBi12 do it's thing will most likely be ok. Most chargers have 3 basic stages:
1. constant current
2. constant voltage
3. trickle voltage
During 1, it'll put out its spec'd current (15A in your case) until the voltage reaches a setpoint (typically 14.something). As it passes through the low 13s, your SBi12 will close and that 15A will then be shared between both batteries. They'll both then climb towards the setpoint voltage together. When they get there, the charger will then maintain that voltage (stage 2), and each battery will continue to draw what it needs until fully charged. One will probably get there before the other in which case you'll be feeding it 14.something even after it's indicated it's full, but that's no different from what classic alternators do... output 14.4V all day long, and the battery needs to be able to survive that. Eventually they'll both be full and the total current will drop low enough that the charger will move to stage 3 whereby it'll just put out 13.2V forever. From memory my SBi12 didn't used to open until the voltage dropped down to about 12.6V, so both batteries will enjoy the trickle charge until you disconnect.
That's the theory ... there's a chance your charger may do something different so maybe keep an eye on it the first time you try it. If its setpoint is a lot higher than 14.4V then there's a risk you might be overcharging the battery that reaches full first. Some chargers let you set that setpoint by way of telling it the battery type (classic lead acid, AGM, calcium etc). If you're charging two in parallel it's probably safer to go with the lowest setpoint.
Leave a comment:
Hi all, I hope your all going well. I've got a recharging question when using a 240V DC charger on a dual battery system.
I've recently got a Ctek MXS 15 amp charger to try resurrect the missus' car battery and top my Prado up whilst I'm at it. With the 2014 GX Prado running a SBi12 isolator based dual battery system (basic lead acid batteries x2), can/should I just connect my main battery to the charger like normal and leave on? Will it charge both main and aux properly?
I understand the isolator will stay on when voltage is above approx 13ish volts, but will the isolator confuse the Ctek, when analysing / float trickle charging? Using recondition mode on the charger will also try analyse two batteries will it not?
Any hints or suggestions are much appreciated!
Leave a comment:
Leave a comment:
