MickL is a valid member, has been since he stopped having time due to family and work issues.. I'd suggest having correct facts..
The 150 series Dual Battery Guide
This is a sticky topic.
Interesting argument.... lol@sock puppets.
As a side question then. When do you guys suggest using a C-Tek type charger? For instance, I recently converted a LWB HiAce into a camper for a customer. Now this fella was a greenie through and through... He was a vegan and also burst into tears when I wouldn't budge on the invoice if that helps define the character heh. His want was to be able to camp as long as possible without starting the car.
So, we settled on 160 Watts on the roof, 4x50AH AGM batteries and a C-Tek D250S and needs to run a fridge, 600watt inverter from time to time, CD Player and LED interior lighting.
Currently, he has been camped for two and half weeks without starting the car.
Could I have done anything differently? I honestly couldn't see a better option.
Hi RanJ and with 200Ah of battery capacity ( 160Ah available ) and the long stays, if his batteries are discharged down to their safe limit, 11.58v or 20% SoC, to get the batteries back to around 95% or a bit higher, with the Ctek charging the batteries, he will need to drive constantly for 10+ hours.
Whereas, if he has a late model Hiace with low operating voltages, as I have posted above, he could have fitted one of LeighW’s Alternator Voltage Booster fuses and my isolator.
With that set up, he would have had 200Ah available ( the extra 40Ah being provided by his cranking battery ) and would be able to charge all the batteries to around the same 95+% in around 5 to 6 hours of driving.
Plus, he would have obviously used a lot less fuel, but don’t tell him as he will probably just start to cry again!!
Or at a much higher set up cost, you could have fitted a 40 amp DC/DC unit.
He would still only have 160Ah available but then he would have only needed to drive about 6 hours, to get the 4 batteries up tp around the 95% mark.
Hi RanJ and even at 11.92v or 40% SoC, if he started his drive in the morning, not giving the solar time to start recharging his batteries, he is still looking at around a 6 hour drive.
Because of his long stays, fitting a second solar panel would be the best improvement you could do to his existing set up.
I'm not sure what you mean... He has two 80watt panels fitted to the roof. Hasn't started the car in two and a half weeks and hasn't dropped below 11.92 during the night. I mean essentially we don't need to improve it as it's working perfectly.
I was asking how it could've been done differently. Sorry to confuse mate.
http://www.energymatters.com.au/aero...ine-p-511.html
Originally posted by RanJ View PostI'm not sure what you mean... He has two 80watt panels fitted to the roof. Hasn't started the car in two and a half weeks and hasn't dropped below 11.92 during the night. I mean essentially we don't need to improve it as it's working perfectly.
Charging from the car if required could have been done as Drivesafe suggested.
Bottom line though is if it ain't broke don't fix it.
LeighHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Battery Trays
Team,
How many of you have utilised the factory 2nd battery mounts already available in the prado?
It looks as though i can get away with a $10 plastic tray and $10 clamp from supercheap and the battery will be just as snug as the main battery.
Am I missing somthing here? Most people seem to be spending $150 plus on aftermarket battery trays.
Swanie
Apart form the guards cracking you haven't missed anythingHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Generally the aux will be heavier than the cranking battery, anything you can
do to spread the load away from the guard would be a idea. The after market
trays mount to lower guard and also to the side guard and also have a support
bracket to the radiator, well at least mine does. Doesn't spread the load much
but somethings better than nothingHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Thanks for the feedback leighW.
Has there actually been any reports of gaurd failures yet?
I am going to risk it anyway. The weight difference between the battery's will be negliagable. I am sure the engineer's at toyota will have rated the gaurd to suit.
I will report back if any failure occurs.
Swanie
