I am finishing off the wiring to my van and all cabling is in place (from my last prado) and I intend to replace the solenoid with an automatic unit. Either Redarc SBI12 or the Projecta 100A unit ? Any bad experience with either ? Where to get the best price around Newcastle ?
Redarc or Projecta ?
Re: Redarc or Projecta ?
I've seen them go for $60 brand new delivered.Originally posted by bilo33pradoi bought one for $90 delivered, great product.Originally posted by DavrosRedarc SBI12 is available from eBay for $105.00 delivered. I bought one on Monday night, and it arrived this morning.
I bought a Redarc on eBay for $100 delivered. It works great and is dead easy to install. It seemed like a good quality brand which is why I bought it over any other isolator.
VXWesty[SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
[/SIZE]
I've had the projecta 150 which has been in 2of my cars & it works great.. The prado doesn't have many places to mount but these have a L bracket that goes under the existing battery so no need to mount or drill.2010 Prado GXL D4D Auto , BFG A/T , DVD Console , Tekonsha P3 , Projecta Dual battery system , Piranha dual battery tray..
Jayco outback expanda
I went Redarc, have heard of a few problems with the Projecta's if they get wet. Just through the experiences of some mates over the years, none of them with Redarc's have had any problems.[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
Hi Guys,
Just doing the research on dual battery systems at the moment – have done searches already but still a little confused… feel free to make any recommendations etc.
My needs to start with will be basic– just to run a fridge, dashcam and CB but I wouldn’t want to limit myself in the long run – may end up looking at campervan / caravan etc. I was also contemplating eventually getting a winch on winch bracket to use at the rear rather than replace my current bull bar so having an Anderson plug at the rear will be beneficial.
Looking at the Redarc SBI12 and Projecta DBC100 / DBC150 kits – the Projecta DBC150 kit is about the same price as the Redarc SBI12
A friend at work has the Projecta – I like that is has the built in override control (though under the bonnet) – does the Redarc have this capability? It doesn’t look like it from what I could see….
Should I be worried by the peak amp rating between the two?
Projecta DBC150K $179 ebay delivered
125A Continuous
150A Peak
Cut in: 13.4v
Cut out: 12.8v
Delay: 60 seconds
Built in manual override (bridging)
Projecta DBC100K $139 ebay delivered
75A Continuous
100A Peak
Cut in: 13.4v
Cut out: 12.8v
Delay: 60 seconds
Redarc SBI12 Kit $186 ebay delivered
100A Continuous
400A Peak
Cut in: 13.2v
Cut out: 12.7v
FYI - also planning on voltage boosting diode.
Also planning on mounting a dual battery volt meter (Projecta’s is about $100 delivered from ebay)
I read the remark on issues with water - I don't plan on any water crossings, certainly none that should get the unit submerged!
Kevin
Thanks for that - ended up finding it through Redarc site.Originally posted by Vk3zgw View PostThe Redarc has an override. It is the blue wire which can also be hooked up to a led to indicate when the solenoid is activated when both batteries are connected together.
http://www.redarc.com.au/handy-hints...ic_sbi_install
Alot of effort to go through for an override considering Projecta has it built in....
Don't forget Traxide, they offer a 5 year warranty and
a lifetime repair guarantee, also made in OZ.
LeighHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
