fitting uhf
  • fitting uhf
    hi every one just bought a prado 150 series 2012 and i am fitting a uhf where is the best part of the wiring loom to hook infer the power for this thanks i thought better to ask before i cut ??? thanks tom
    Mine is connected directly to the battery, if you need to use it without the keys it can be
      thanks that was one of my thought
        For that very same reason I connected mine to the second battery. (None of my after market accessories are connected to the starter battery for obvious reasons.)
          yep second battery run a multicolored cable through the firewall grommet so you have spare wire for future additions.
          No second battery yet use Main battery for now same idea
            I earthed mine to the body and ran power to the sunroof fuse since I don't have one. It stays powered on for a while after you turn the car off so you can still use it but will turn the UHF off if you forget to.
              thanks guys for you in put i went straight to the battery tommy
                Sunroof fuse - I like that idea. How did you tap into it?
