Charging Test
  • Charging Test
    My alternator is charging at 13.65v at idle. Do I need to replace the alternator or is it ok?
    That's most likely ok for a standard alternator.
      hey LeighW what does the alternator charge up to with one of the diode fuses fitted?
      are all the 150 canbus?
      are you still selling them on ebay ?
        You will get about .5V-.6V increase, can't be used on the 2.8Ltr engine.
          Thanks guys for your input.
          I spoke with the auto electrician and he said 13.65v at idle was normal.
          He also mentioned the most common problems he has seen lately is the clutch pulley on the alternators needing replacement at less then 200k.
          I also asked that question about how long alternators should last and was told anywhere between 40k and 280k depending on many factors.
            I have had over 300000 out of an alternator but I did pull it down and service it at 150000,
            13.6V at 24C is pretty much normal for a low voltage alternator.
