3 way / SPDT switch matches OEM
  • 3 way / SPDT switch matches OEM
    Hi guys.
    Has anyone come across a 3 way rocker or spdt switch that fits in an oem blank?
    TIA
    You could use a Lightforce (Custom switches) they do a dual switch. this could be wired to be a 3 position switch easily. Not sure if they do a SPDT you'd have to check.
      The Lightforce ones are SPDT but the NC side isn't connected on the board to the connector. Easy enough to mod if you have the skilz..
      The switch is actually DPDT but one side is to control the LED illumination.
      Click image for larger version  Name:	20190615_150358.jpg Views:	0 Size:	10.1 KB ID:	753662
      Click image for larger version  Name:	20190615_150625.jpg Views:	0 Size:	11.1 KB ID:	753663
