Originally posted by Riv39
View Post
Engine rattle
Originally posted by krypto View PostI use BP diesel, but there is no way that Toyota can tie your warranty to only using one brand of diesel. While up north recently I had no choice but to use other brands, happy for Toyota to ship in some BP diesel for me
I think you'll find BP is the only company which guarantees their diesel specs (which are correct for d4d), maybe caltex vortex meets spec too?
I think as standard cetane is 46 and Toyota say should use 50? Maybe someone can correct me on all of this.2011 150series GXL
Originally posted by wooley View PostThey can't tie you to a single brand of diesel, but they can tell you what the specification of that diesel must be.
I think as standard cetane is 46 and Toyota say should use 50? Maybe someone can correct me on all of this.[B]Steve[/B]
krypto, did you notice that 'additional' leaflet in with the owner’s manual etc? It was separate to the actual owner’s manual and clearly added in addition to the other documentation. It had a clear warning that the D4D required good quality fuel purchased from (I think it said) a reputable supplier (or something to that effect). It also had something about ensuring you use genuine filters. I'll have to recheck the wording. Not sure whether this was added locally (Toyota Aus) but I suspect so. Now if you’re a conspiracy theorist you would probably believe that they don't trust some of the fuel available here in Aus...who knows. But I certainly will always use BP and keep the receipts, not for the Toyota warranty necessarily (although it may be useful to counter them blaiming an injector problem on fuel) but to use for BP's warranty regarding contaminated fuel.
Wooley, they only state 46 cetane (the Aus standard) in the manual. Others on this forum believe the D4D requires 50+. I've posted elsewhere on this but my research indicates that only BP ultimate diesel is guaranteed to be 50 +. BP did tell me that the vast majority of their diesel exceeds 50 anyway and Ultimate is not available in NSW. Caltex is only 46 (including Vortex) although they claim to mostly exceed it unless the fuel has been imported. Shell is supposed to be 49+.Last edited by Riv39; 03-11-2011, 08:32 PM.2010 150 Glacier White GXL D4D Auto
i agree with Riv. i have also been using BP since new and kept receipts just in case. recently had mine serviced and had a discussion with the service manager. he tells me that the D4Ds with issues are those with contaminated fuel i.e- mixed with petrol. in particular, there's one with a fuel pump totally destroyed as it blew up when it sucked in petrol. apparently it was the driver who made the mistake.
i've always been careful when at the bowser and have made it a point that i will be the only one to fill it up.
question. why is it that the bowser sizes are similar for both petrol and diesel and "accidents" can happen? wouldn't it be sensible to alter shapes like make the diesel bowser a double barrel with both tubes smaller but still maintain the volumetric flow and for the car inlet a figure 8?
for the rattle issue, i've asked a few owner/drivers and one especially who does lots of start stop driving (van with the D4D) and by stopping, he meant engine shut off. in the 4 years and 95,000 kms he never had a problem. usual service done as required at Toyota. has he been lucky? or rather it was him being careful with the service schedules, etc..i like rock and roll... in my Prado.
Bert, if you use a high flow pump there can be no confusion as the bowser size is large along the entire length. I reckon the confusion is from people not being used to a diesel engine and just go straight to the unleaded bowser out of habit. The other giveaway is the oil everywhere....my misses refuses to fill the car up anyway so I'm safe (not to sound sexist).2010 150 Glacier White GXL D4D Auto
Originally posted by krypto View PostSo what to do if you are driving where there is no BP or Caltex such as some parts of the bush? The Toyota ads emphasize that Toyota's are built for the outback, I think they'd be hard pushed to make a case. Any lawyers lurking?
Also occasionally use CHEMTECH "Diesel Power" additive, especially when refilling at remote or low volume suppliers, as it not only cleans injectors, but assists with clearing water in the fuel. Its australian made, and I spoke with the actual chemist who makes the products at a 4*4 show recently, and it is definately safe to use with the new Prado 150.SE Qld: GX 150GD Auto, (Feb'16 build): TJM T15 steel b bar, 9,500lb TORQ winch, TJM s steps, Rhino Pioneer Platform (42102B 1928X1236mm), front recovery points, Wynnum towbar, P3 brake controller, TNN Underbody guards, UHF, TREKtable & LED striplight, Custom Fridge & Drawers, Waeco CFX50, 9inch illuminator 160W LED spots, 40mm lifted Dobinson Suspension (Zordo's), ScanguageII, 30 Sec Wing Awning
Where's a good place other than Toyota to go to have the injector feedback values checked for a reasonable price?
My engine runs fine but is a bit rattely sometimes under light load and occasional cold knock. I've done 95 000km and the rattliness is under light load is more noticable after long road trips (1000+km). The car runs very smoothly after these long trips but the noise is a worry.
I don't have a lot of spare time to go back and forth to the dealer so I'm after an independant test and one trip to the dealer for a replacement if necessary.
Thanks,2019 GXL, Bullbar, UHF, Redarc Brake Controller, Tow Bar, Secondary Fuel Filter
That was an informative read Roo.
Just to clarify, you have found that the injectors aren't overworked when compared to the injectors of other CRD engines, so that means its the quality of the material that's to blame for the premature wear of the injectors?
Also are D4D engines (1KD-FTV and 1VD-FTV if its used) in Europe also experiencing injector failure? Was the issue of material quality addressed by the replacement injectors?[B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
Interesting read Roo, I had my injectors checked at 20,000km and all ok according to the dealer who showed me the numbers. I am going to have the dealer check them every 10,000km. I'm also going to take out an extended warranty before I hit my last year of factory warranty.2010 150 Glacier White GXL D4D Auto
The issue for me isn't that the early 120s had a problem; and not really even that the last ones have issues but that the problem continues now with the latest iteration of the D4D.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Roo, I did ask my dealer about replacement (if required) and they immediately said yes all four need to be done. Good start if I ever need it (hopefully not). I have a pretty good relationship with the service manager (yes I've spent my fair share of time going back with problems like the binding shaft etc) so hopefully things would be ok if the worse were to happen.2010 150 Glacier White GXL D4D Auto
Just a quick Q. Do any of the members suffering from the cold engine injector rattle have some sort of aftermarket performance chip fitted. I notice that mine is a bit noisy first thing in the morning but only until the engine begins to warm up. There shouldn't be any cold weather issues up hear in the north west of W.A, however I may try it tomorrow morning by unplugging the chip and seeing how that goes. Otherwise I'll get the dealer to check the specs on the 20000K service.
Chris.SOLD!!! 2011 Prado GXL manual in silver
ARB Winchbar, Lightforce HID's, 3" SS Manta exhaust, 3" Monster Rides suspension system, Tracklander roofrack, Ostrich wing awning, Kaymar dual wheel carrier, Gturbo stage two Grunter and reprogrammed ECU. Trackabout Dakar SV Extenda. Purchased 2017 Landcruiser 200 Altitude.
Chris,
Ours has approximately 35,000k's on it.
I fitted a chip it chip about 1,000k's ago, until then it was pretty quiet, it does get a bit noisy when it's due for a service.
Since I fitted the chip it is noticably noisier at start up, it's not just me either both my wife and son have commented separately.
The rattle stays until the engine is at running temp, ie the temp gauge stabilises, then it settles down to the noise level it was at prior to fitting the chip, maybe a bit louder but not much.
Hope that helps,
Greg
