UK vs. AUS Engine. Why is their diesel 140kW
  • UK vs. AUS Engine. Why is their diesel 140kW
    Anyone know why the UK Prado (Landcruiser asits called there) is a 140kW engine rather than our127kW?
    Has it always been or did they come up with a facelift engine at some point?
    Is this somethig we're likely to see here?
    2012 Kakadu
    My 2009 UK LC4 is 127kw. Facelift engine around 2011 I think.
      Sure it's not HP vs KW?
        That would be 170hp
          EDIT: Davros beat me to it.
            Back to my corner....
              Mine's a Sep 11 so no "facelift" here I guess!
                No it's 140kW
                Bore (mm / in) 96.0 / 3.78
                Stroke (mm / in) 103.0 / 4.06
                Displacement (cc / in(cub)) 2982 / 181.9
                Max output (kW) 140
                Engine speed for max output (rpm) 3400
                Max torque (Nm / lbft) 420 / 309.54
                Engine speed for max torque (rpm) 1600
                2012 Kakadu
                  Probably because our diesel is shit in Aus compared to Euro Diesel, hence the motors are detuned for out crap fuel. I think we run higher Sulfur content in our diesel than euro. Im not 100% on this so dont quote me as gospel!
                    Ryzz
                    Not sure whether our crap cetane spec of 46 or better explains everything that's a fair difference 127 vs 140
                      Compared to our Aussie Prados, the UK Prado has +13kW and +10Nm. Whilst more is (nearly) always better, it doesn't seem like much of a difference; just a slight tuning?
                      Given a fairly expensive chip will improve things from 127 to 150kw and 410 to 495Nm, I'm guessing it wouldn't take much effort for Toyota to squeeze out an extra 13kW and 10Nm, regardless of fuel quality.
                      What does the UK specs list for fuel economy? The Aussie D4D A/T Prado list 8.5L combined, 10.6L (urban), 7.3L (extra).
                      LFaR.
                        UK Specs 8.1 but ours is done under ADR, theirs is possibly different
                        2012 Kakadu
                          But in reality we don't achieve those numbers for fuel economy more like 10L combined, 12L (urban), 8L (extra).
                            The 5 door Prado in the UK misses out on the long range tank and has a towing capacity of 3000kg.
                            I think Toyota Australia is going down the path of being conservative. Maybe its because we are a much hotter country.
                              I think is more to do with our poor fuel.
                              2012 GX Prado 150 D4D Glacier White Auto with colour coded Rear Kaymar Tow bar Step, TJM T13 Bull bar, Safari snorkel, 100A Lifeline Battery, TJM battery tray, Redarc DC-DC 40A charger, 8" in dash GPS, Speedy Avalanche Wheels, Coopers 265/65 r17 AT3, AMTS Bash plates, TJM Side Steps, Ultimate Suspension 2" lift, Premier Winch.
