UK vs. AUS Engine. Why is their diesel 140kW
    what is wrong with our fuel?
      Our diesel has a low octane rating and also has a higher sulfur content. The EU is also having to meet EU5 standard
      Sent from my HTC Ruby using Tapatalk 2
      2012 GX Prado 150 D4D Glacier White Auto with colour coded Rear Kaymar Tow bar Step, TJM T13 Bull bar, Safari snorkel, 100A Lifeline Battery, TJM battery tray, Redarc DC-DC 40A charger, 8" in dash GPS, Speedy Avalanche Wheels, Coopers 265/65 r17 AT3, AMTS Bash plates, TJM Side Steps, Ultimate Suspension 2" lift, Premier Winch.
        "Our diesel has a low octane rating"
        I'd be worried if it didn't
        2009 Prado 150 D4D GXL with 265/70R17 Cooper AT/3 tyres, Max Trax, HR tow bar, Airtec snorkel, UHF and the usual recovery gear. On the list: cargo barrier, Bilstein shocks and King springs, deluxe winch bar, 10000lb winch, Lightforce 240 XGT spotlights, dual spare wheel carrier
          from what I can gather, their standard is very similar to ours.
          I don`t think fuel is the issue at all, it used to be but not anymore.
            LOL!
            It could be a reliability/longevity thing...
            Less power from a motor and it 'should' last longer.
            2011 150series GXL
              Not lower octane but lower cetane as I posted earlier. The Aus standard is 46 or better, the D4D really needs 50 or better which is only available in Aus (guaranteed) using BP Ultimate diesel which BTW in not avaialble in NSW and possibly only in QLD where they have a refinery.
                Can get it in selected servos around WA, although not sure if that includes any outside Perth.
                Kev,
                  As per my post in another thread, the minimum Cetane Index in Oz is 46 and the minimum Cetane Number is 51 just as is the case in Europe. As is the sulphur content. The latest standards (post 2002) were adopted at exactly the same time. The quality of Australian fuel [matching apples with apples] is exactly the same in Australia as it is in Europe only the European standards allow for up to 7% biodiesel while the Australian ones allow only up to 5%.
                  http://www.environment.gov.au/atmosp...sel/index.html
                  http://en.wikipedia.org/wiki/EN_590
                  The manufacturer's recommendation for minimum Cetane Number for the Prado 150 is 48, the Australian (and European) standard of 51 more than meets this requirement.
                  Also the MDS for BP Ultimate does not guarantee a Cetane Index of 51 but rather a minimum cetane index of 46 and a typical index of 52.
                  http://www.bp.com/liveassets/bp_inte...ate_Diesel.pdf
                    Originally posted by Kowolski View Post
                    Anyone know why the UK Prado (Landcruiser asits called there) is a 140kW engine rather than our127kW?
                    Where did you see this? The only reference to the power output for the Land Cruiser LC4 I can find is 169 bhp (126 kW) so if you allow for a minor rounding error somewhere is exactly the same.
                      I don't know if this link will work but Toyota UK's specs for the 150 clearly say 140KW
                      http://www.toyota.co.uk/cgi-bin/toyo...yota_1024_root
                        Ok, thanks for that - weird
                          Doing some more digging, looks like the 190 hp version replaced the 173 hp version in 2011. Haven't been able to find any more specifics though.
                          • #28
                            And found this in the archive - http://www.pradopoint.com/archive/in.../t-17653.html?
                            • #29
                              While digging the net months ago, to find out why my Prado delivery was delayed so much, I found a web site that was announcing the 140kw engine for the EU market and just below was adding that for the time being, Toyota Australia decided not to get this upgrade.
                              No other explication.
                              I thought that the diesel quality may be a good reason or a limited stock availability of some part used to upgrade the engine.
                              Ciao
                              Marco
                              • #30
                                1 - Does the current model Prado have a Diesel Particulate Filter?
                                2 - Have there been any issues with it (as VW's, BMW's, Audi's and countless other European cars have had)?
                                2012 Kakadu
