Can't remember the size of the fittings, if you look in the 120 section is probably
in there as that's where I would have got it from.
I have a 120, I fitted the unit same side as the existing filter on the fire wall,
there is to un-used threaded studs there on the 120 so just made a bracket
up to use them, moved on fule line to Racor and around 300mm of hose to
from Racor to existing filter.
Easy enough to change element if you get the correct tool though you do need
to remove the filter from the car to do it.
Leigh
Leigh
