Hi gang, I'm a new member with a problem!
I have a 2010 150 series diesel Prado, with 74000 k's, been serviced by the book
yesterday (7/11) warning lights came up Engine man, 4WD, traction control etc. and the motor cut out, limped back to Toyota dealer, they looked at it and FOUND A FUEL LEAK at the common rail (not at the injectors )it was leaking down on to the oil filter.
their solution , replace the fuel lines to the injectors, no idea were the leak was!!! but this should fix it.
No mention about possible fire risk, just the $560 for the pipes + fitting.
Left the car and asked Toyota to come up with a better answer and solution
Looking for outside help too
Cheers Bill
Cheers Bill
