Steinbauer chip and new exhaust
    This is the bracket i made. After proving this i welded it to the exhaust and removed the clamp. Mounted from the bolt on the gear box to just in front of the flex bellows joint. Showed it to Tiapan exhausts but they didn't use it on the replacement exhaust, so i made a second one and installed it. The dump pipe has a good support bracket and with this one the exhaust stopped excessive movement at idle speeds.
    25 x 3 mild steel.
    *bellows.
      25 x 3 mild steel.
      *bellows.
      Beaudesert's have a similar bracket.
