Originally posted by Anth120playdo
View Post
Injectors
Originally posted by garbage View PostWhat's the lowest mileage someone has heard of this happening to a 150 series?
#### - are you seeing examples without chips also blowing?
Prado 50 odd k.
Not many that low, most of the low Klm's ones are members here. A few around 70-80k not many.
The numbers increase a bit from there usually 120k is a pretty safe number.
The modified vehicles, with or without chips & towing seems to more common.
Chips are not helping at all.
DIAGNOSTIC by an expert every 10,000k is your number 1
Many people are becoming aware of the issue.
I saw a 150 today, from the Bendigo arb sticker he was on the way back to Bendigo, lots of ugly puffs of smoke, definitely not looking good for him. I felt like I needed a set of blue & red lights so I could pull him over & give a warning.
Poor sods who not on forums & go to Toyo.
Originally posted by garbage View PostWhat kinds of non-chip mods have you heard of that have gone bang?
Usually when one has popped it's a modified truck not a stock standard one. Usually towing. Coinsedence?
When you put bigger tyres, more weight, add wind drag, you make it work harder.
I had my injectors replaced today with the baileys ones. Just wondering what values I should see now. The bloke said one of the injectors was +2 when it was cold. when I drove off the temp gauge was cold but didn't take long to warm up. Would the car be running to install the codes? Just wondering if this is normal. I intend to get some readings when I can get to my local mechanic.
Cheers Matt2008 120 GX D4D with a few extras
Rig build here
Originally posted by Mattfunk 120 View PostI had my injectors replaced today with the baileys ones. Just wondering what values I should see now. The bloke said one of the injectors was +2 when it was cold. when I drove off the temp gauge was cold but didn't take long to warm up. Would the car be running to install the codes? Just wondering if this is normal. I intend to get some readings when I can get to my local mechanic.
Cheers Matt
What was your old readings?
Is it the same pot as the old ones that has the high reading?
Injectors
Originally posted by Anth120playdo View PostGive them a run, re-check & monitor closely.
Thanks MattLast edited by Mattfunk 120; 06-07-2015, 09:56 PM.2008 120 GX D4D with a few extras
Rig build here
Originally posted by Mattfunk 120 View PostHi #### , not sure if it's the same pot ( I assume this means the same injector position)as my worst previous reading . I didn't record last reading , was just told to start saving when I had a mate check them . I think the worst was around 3.5 and volume about 13.
Thanks Matt
That's why it would be a good start to know what the exact previous & new readings are.
So this 2+ is it cold only & comes back pretty quick? Or not much improvement when warm?
The codes are entered before you start up.
Injectors
Originally posted by Anth120playdo View PostSo this 2+ is it cold only & comes back pretty quick? Or not much improvement when warm?
The codes are entered before you start up.2008 120 GX D4D with a few extras
Rig build here
Originally posted by Mattfunk 120 View PostI'm a novice still , when you say " come back" are you referring to the values increasing?(when engine heats up)
Often they improve as they warm up, sometimes they don't.
Interested to know if they got it warm or just switched it off.
Come back was meant to mean come back down
Originally posted by Anth120playdo View Post.
Interested to know if they got it warm or just switched it off.2008 120 GX D4D with a few extras
Rig build here
