Originally posted by Brett1979
View Post
2015 2.8 litre Engine
There are stories I could tell about them being used on remote mine sites that support that comment - I wouldn't touch them!2016 Toyota Prado GXL auto. ARB deluxe bar, Rock Armor side steps, 9in Penetrator LED spotties (30,000LM), Uniden 8060 UHF, Bilstein/Dobinson 2in lift, 265/70/17 Mickey Thompson ATZ P3's, Safari snorkel, Dual battery system, ARB onboard compressor, Custom rear false floor, Kaon bash plates, Ext. diff/gearbox breathers, Provent 200, Wynnum tow bar, Roadsafe tow points, Phillips crystalvision bulbs, tint, Rhino rack platform.
Yes I was referring to the Ford Ranger. I haven't read much on the Everest.
You will aways get complaints on any car on any type of forum, but I do read a lot of bad stories regarding the Ford Ranger. First hand stories.
Just a quick glance at the Ford Ranger:
http://www.productreview.com.au/p/fo...5-present.html
http://www.productreview.com.au/p/fo...7-present.html
And then the Prado:
http://www.productreview.com.au/p/to...9-present.html
When I first got my 3.0 it was doing 7.5 on a 1700km run In winter. That was the third tank, one whole tank.Originally posted by pradodp View Postfurther update about fuel consumption: it's better and it reaches 8.6l/100km for 800km highway driving.
quite good, and wonder if 8l could be reached at next stage.
Sent from my iPhone using Tapatalk[CENTER][B]-=2014 GXL D4D Auto Graphite, Firestone Airbags, ARB/Optima D34 Dual Battery, ARB UVP, TJM Airtech Snorkel[/B][B]=-[/B]
[/CENTER]
I went from a 3.0L 150 to a 2.8L 150. Towed our 1.2T camper for the first time last week about 1500km. I don't know what I think yet about the towing. It certainly doesn't tow better then the 3.0L despite the extra 40NM torque. The 6th gear is way too tall for towing anything so i left it in 5th the whole way. 6th gear only seems to be good when car is unloaded and on a flat road. Any sign of a hill it goes back to 5th. Aparently 5th gear in the 6 speed auto is the same ratio as 5th in the 5 speed. (so the new gearbox has 2 overdrives). My old 150 used 12.5L/100 towing the camper and the new prado used 14.5L/100. Hopefully this gets better since I only have 13000km on the clock.
I know that this has been discussed a lot, but just a reminder that towing in overdrive gears under load is a recipe for disaster. Ran into a bloke up north the other day who pretty well cooked his gearbox doing this. In O/D the gearbox tends to fall out of lock-up pretty easy and then you get the torque converter heating up the oil pretty quickly.Originally posted by pjtaylor3 View PostI went from a 3.0L 150 to a 2.8L 150. Towed our 1.2T camper for the first time last week about 1500km. I don't know what I think yet about the towing. It certainly doesn't tow better then the 3.0L despite the extra 40NM torque. The 6th gear is way too tall for towing anything so i left it in 5th the whole way. 6th gear only seems to be good when car is unloaded and on a flat road. Any sign of a hill it goes back to 5th. Aparently 5th gear in the 6 speed auto is the same ratio as 5th in the 5 speed. (so the new gearbox has 2 overdrives). My old 150 used 12.5L/100 towing the camper and the new prado used 14.5L/100. Hopefully this gets better since I only have 13000km on the clock.[B]Steve[/B]
Just wondering- and noting the date and the Km's used - could perhaps you have had the updated firmware for the auto at the 10K service perhaps?
Mine's only around 2500km's old and getting around 9.7 - 9.9L/100 by the digital readout. I'm interested to see what happens when the Bar/ Lights and OME goes on in a month or so...
We have a 2016 Kakadu and feel the motor is good but as a lot here feel it's a little under powered another 10kws would go along way, also owning a Everest that does get up and move with less effort, thow I do like the gearbox in the Prado better. We just got back from a 1000km trip combined hwy, fwy, city and off-road driving we averaged 10.5lts per 100. Our Everest is averaging 11.5lts
The Prado only has 6k on the clock so I'm sure fuel economy will improve and after its 20k service we will look at flash tunes ect. really would like some better low end response, happy now but after we get it set up for touring. I'm sure it will need a little boost
Without bar, light, I got around 9.1L and that was before 15K. Now with ARB bar, Lightforce HTX, Thule Aero roof bar, it sits at 9.7L. I hope I can manage to be below 10.5L after 2 inch lift, All terrain tyre and dual battery. BTW, the car is 50 Percent highway, 35 percent windy hilly road, the rest is urban driving.Originally posted by CamJam View PostJust wondering- and noting the date and the Km's used - could perhaps you have had the updated firmware for the auto at the 10K service perhaps?
Just a bit of thought - particularly for people not happy with the move from 3.0L to 2.8L - have you tried switching the ECO ON to ECO OFF? I've done that in the past thousand + km's and have noticed an absolute zero difference in fuel usage (going by the read-out, which whether it's correct or not would be the same for the ECO ON or OFF) but the pick-ups much better, the shift down is much quicker and freeway driving feels much better. I never had a 3.0L so I can't compare it, but thought it might be worth a try.
I am thinking this ECO thing is simply there to pass an emissions test (like auto stop/start cars) and works in the laboratory, but is better switched off in the real world. I'll certainly be keeping mine off.
Eco switch has a placebo effect whereby your right foot is less brutal on the go pedal. You think you're doing better in the economy stakes.Dave
Yep - it's on the same button that scroll's through your Ave fuel consumption etc etc... under the dash light dimmer switch. Once you get to ECO ON, press and hold, and it goes to ECO OFF.
Reference placebo effect - I can categorically say - dead wrong. It changes the throttle response and the adjusts when the gears change. Don't just take my word for it though - go out and press the button yourself! Try it on a similar loop - it works.
The other benefit is that it gets rid of the green ECO light that kept lighting up all day/ night.
And this is on a 2016 2.8 GXL
