Toyota Prado Recall (Code GGG38) ECM Reprogram
  • #46
    Originally posted by Phs View Post
    Any reports of fuel economy after update ?
    Yep down to 8.7l/100km at 110km/h. Used to be mid 10's
    • #47
      @ 110 km/h
      What is the overall economy ?
      • #48
        @ 110 km/h
        Last tank mostly city driving 10.08l/100km. Sits around 6's when doing 70km/h
        • #49
          Very nice,
          • #50
            Hey Cuda, you mentioned previously your dpf was replaced, was that done at the same time as the ecu update.
            • #51
              Yep both done at the same time.
              • #52
                I think you have double the benefit then!
                Those are some pretty good figures mate.
                Micheal.
                • #53
                  Cuda's figures are good
                  I will have to book ours in, ATM we are sitting on 11.2lts cars is fairly well set up lift, winch, duel batts ect. motor is on 22k most driving is inner / outer Melbourne suburbs
                  Would be wrapped if it was into the 10s
                  • #54
                    Need to book mine in. 14L per hundred running around empty is pathetic....
                    • #55
                      Where can I find my recall detail? I saw the recall notification in my garage a few weeks ago. but when I log in just now, I couldn't find it.
                      • #56
                        Had mine done just before a holiday trip last week. Only took 20 mins to do. Seems to be running slightly better overall and obtained 7.5 to 8.5 on long runs with 4 adult passengers, full tank and a boot full of luggage. Still on original DPF filter at 15k.
                        • #57
                          Far out that is pretty good economy. There has to be something wrong with mine. About to fill up after the ECU update and I don't think I will get under 11 and that is with about 400ks of highway driving.
                          • #58
                            Likewise - mine's so far hovering around the 13.0/100 mark. Only had 500km's post the upgrade, but here's hoping that's simply because it's buzzing the begeezus out of the DPF for now. I usually get around 10.8 on the same kind of trips...
                            I noticed last Saturday (I took it in on Monday) that it blew some white smoke. Glad I had that bit of info so they could record it down as an issue for later (potentially). As I get it serviced from non-Toyota I don't get to see them very often. But they were quick.
                            • #59
                              Guys this might sound stupid, but those of you getting poor economy when doing highway/freeway travelling, is your box engaging 6th gear? My box needs to really be coaxed into 6th gear by really pulling back on the throttle when reaching the desired 100/110/120km speed, and drops back to 5th at the mere suggestion of an incline, which then results in another coax into 6th once on flat surface again. I usually get around 9-10l per 100 around Perth metro, and when on open road can get 7.5-8.0l per 100 when on the highway at 120. I don't drive it like I do my V8 Commodore, but I don't putt around either.
                              Re the ECU update, Ill get this done when my next service is due in 2000km.
                              • #60
                                At 100kmh, if you see about 2000rpm on the tach, then you are probably in 6th, but the torque converter is not locked. There was a gearbox firmware update earlier this year, but I didn't notice any change in the behaviour at highway cruise speeds.
