Thanks ExNissan and RPP to come up with the programming. I can confirm codes to work in my Prado 150 MY2014 1KD-FTV face lift. Haven't done a compare with a computer based diagnostic read, but X-gauge main tank shows 86l and sub is empty. The calculated liters to empty by the Scangauge is 87l and have this calibrated to work quite well based actual refueling amounts to full. So as a plausibility check display is spot on. I actually prefer this as a raw read without averaging, instantaneous sensor feedback is better for diagnostic purposes. If one wants an accurate read then just stop the car and make sure its level, but I can't really see a purpose for doing this. All one needs to know is that sub is kept absolutely empty with a less than full main tank level. Liters to empty is a better trip planning tool, provided the transfer system works.
Again thank you for coming up with the coding!
