Riv Would you send me the number for the tsb thanking you kindly Cheers Foxy
Flat Spot at around 2400 RPM
Originally posted by wooley View Postdoes your cruise control now work in sports mode too?
I was certain that cruise never worked in S. But now... it does[B]Steve[/B]
Originally posted by Riv39 View PostGood to see REV, do you notice that the shifting pattern is completely different and the way it holds 4th a lot more?
It just goes to show if you can deal with one service advisor it makes everything so much easier. When I first reported the hesitation & that I was concerned about it, the advisor that i normally deal with wasn't there that day & another advisor said that it was normal & not too worry about it as every thing was fine.
When I went back in armed with the tsb number, the advisor that I normally (try) & speak to was there and when I told him about the hesitation he said he was aware of an upgrade.
he looked it up & there it was. (surprise surprise) I didn't need the tsb number that you supplied Riv but, thanks very much for your effort & info sharing, this is what makes this forum the great one that it is.
REV
Originally posted by REV View PostYes, in the couple of drives I've had since getting the upgrade yesterday I have noticed a difference in the shifting & more so the way it holds 4th a bit longer in lower speeds. But I am very happy with the results from the upgrade.
REV
No problem at all guys, the forum is great and I'm sure it has contributed to a number of improvements through members efforts.
I must confess that I believe the upgrade has led to slightly worse fuel economy but I still prefer the new shift pattern and no flat spot. I am going to start driving in S mode again for a comparison as I believe it does not hold 4th as much. I'll report back on my findings.
Wooley, I used S mode all the time before the upgrade an cruise worked fine for me.2010 150 Glacier White GXL D4D Auto
Originally posted by Riv39 View PostNo problem at all guys, the forum is great and I'm sure it has contributed to a number of improvements through members efforts.
and I agree, the fuel economy is definitely worse.2011 150series GXL
